跳转到主内容
HP Mini 210 Netbook WWAN Card Replacement
你所需要的
  1. HP Mini 210 Netbook WWAN Card Replacement, WWAN Card: 步骤 1 中的图像 1,1
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. HP Mini 210 Netbook WWAN Card Replacement: 步骤 2 中的图像 1,1
    • Slide the battery out from the netbook.
  3. HP Mini 210 Netbook WWAN Card Replacement: 步骤 3 中的图像 1,1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. HP Mini 210 Netbook WWAN Card Replacement: 步骤 4 中的图像 1,1
    • Use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. HP Mini 210 Netbook WWAN Card Replacement: 步骤 5 中的图像 1,1
    • Pull the back case off from the front edge.
  6. HP Mini 210 Netbook WWAN Card Replacement: 步骤 6 中的图像 1,2 HP Mini 210 Netbook WWAN Card Replacement: 步骤 6 中的图像 2,2
    • Disconnect the two gold antenna cables from the WWAN card using a plastic opening tool.
  7. HP Mini 210 Netbook WWAN Card Replacement: 步骤 7 中的图像 1,2 HP Mini 210 Netbook WWAN Card Replacement: 步骤 7 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the two Phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board.
  8. HP Mini 210 Netbook WWAN Card Replacement: 步骤 8 中的图像 1,1
    • Remove the WWAN card by pulling the WWAN card out at an angle.
结论
Install the new WWAN card and then to reassemble your device, follow these instructions in reverse order.
2等其他人完成本指南。
Heather Freed
于10/06/12注册
723 声望
创作了8篇指南
团队
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G17
3 名成员
创作了8篇指南
2条评论
apakah benda tersebut ada dalam paket penjualan, atau dijual terpisah?
rioarayana - 回复
I wonder sims slot on hp mini and other major brands also. Toshiba ,Acer
Deborah Kisilywicz - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 18
总计 5,727
