跳转到主内容
修复你的物品
维修的权力
商店
简介
Replacing the WWAN (Wireless Wide Area Network) card is easy and straightforward.
WWAN connectivity allows a user with a netbook and a WWAN card to surf the web, check email, or connect to a virtual private network (VPN) from anywhere within the regional boundaries of cellular service.
The WWAN card in the HP Mini 210 uses a Mini PCIe interface, which is the standard on recent laptops. Please ensure you install an official HP verified WWAN card to prevent running into errors.
  1. Turn off and unplug the netbook before replacing the battery.
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. Slide the battery out from the netbook.
    • Slide the battery out from the netbook.
  3. Turn the netbook to view its edge.
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  5. Use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
    • Use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  6. Pull the back case off from the front edge.
    • Pull the back case off from the front edge.
  7. Disconnect the two gold antenna cables from the WWAN card using a plastic opening tool. Disconnect the two gold antenna cables from the WWAN card using a plastic opening tool.
    • Disconnect the two gold antenna cables from the WWAN card using a plastic opening tool.
  8. Use a Phillips #00 screwdriver to remove the two Phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board. Use a Phillips #00 screwdriver to remove the two Phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board.
    • Use a Phillips #00 screwdriver to remove the two Phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board.
  9. Remove the WWAN card by pulling the WWAN card out at an angle.
    • Remove the WWAN card by pulling the WWAN card out at an angle.
结论
Install the new WWAN card and then to reassemble your device, follow these instructions in reverse order.
另外一个人完成了本指南。
Heather Freed
于2012年10月06日注册
636 信誉积分
创作了8篇指南
团队
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G17
3 名成员
创作了8篇指南
apakah benda tersebut ada dalam paket penjualan, atau dijual terpisah?
rioarayana - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 18
总计 5,088
