跳转到主内容
加入维修社区 - 创建账户
HP Mini 210 Keyboard Replacement
你所需要的
  1. HP Mini 210 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 HP Mini 210 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
    询问修复机器人
    添加评论
  2. HP Mini 210 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Slide the battery out from the netbook.
    询问修复机器人
    添加评论
  3. HP Mini 210 Keyboard Replacement, Disassembling HP Mini 210 Back Case: 步骤 3 中的图像 1,1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
    询问修复机器人
    添加评论
  4. HP Mini 210 Keyboard Replacement: 步骤 4 中的图像 1,1
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
    询问修复机器人
    添加评论
  5. HP Mini 210 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Pull the back case off from the front edge.
    询问修复机器人
    添加评论
  6. HP Mini 210 Keyboard Replacement, Keyboard: 步骤 6 中的图像 1,3 HP Mini 210 Keyboard Replacement, Keyboard: 步骤 6 中的图像 2,3 HP Mini 210 Keyboard Replacement, Keyboard: 步骤 6 中的图像 3,3
    • Using a screwdriver, remove the three 6.6 mm screws highlighted with the red circles in the first picture above.
    询问修复机器人
    添加评论
  7. HP Mini 210 Keyboard Replacement: 步骤 7 中的图像 1,2 HP Mini 210 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Once you have removed the screws, flip the netbook over so that the keyboard is now facing upwards. Open the screen as far back as the netbook allows.
    • Using a prying tool, lift upwards and remove the plastic casing that covers the spaces around the keys of the keyboard.
    • Be careful when removing the plastic casing.
    询问修复机器人
    添加评论
  8. HP Mini 210 Keyboard Replacement: 步骤 8 中的图像 1,3 HP Mini 210 Keyboard Replacement: 步骤 8 中的图像 2,3 HP Mini 210 Keyboard Replacement: 步骤 8 中的图像 3,3
    • After removing the plastic casing surrounding the keys, carefully lift the full keyboard from the netbook using a plastic opening tool.
    • Do not yank the keyboard out. The keyboard is attached to the netbook through a ribbon cable, which needs to remain undamaged in order for the new keyboard to properly connect with the netbook.
    询问修复机器人
    添加评论
  9. HP Mini 210 Keyboard Replacement: 步骤 9 中的图像 1,3 HP Mini 210 Keyboard Replacement: 步骤 9 中的图像 2,3 HP Mini 210 Keyboard Replacement: 步骤 9 中的图像 3,3
    • Be very gentle with the ZIF connector! It is designed to be locked into the motherboard, so make sure you lift the retaining latch before attempting to disconnect it.
    • Lift the latch on the ZIF (zero insertion-force) connector using a plastic opening tool. The ZIF connector is located on the motherboard and is connected to the keyboard through the ribbon cable.
    • Disconnect the ribbon cable from the ZIF connector on the motherboard by lifting it up and out; this completely removes the keyboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
11等其他人完成本指南。
团队
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G17
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 42
总计 15,707
