跳转到主内容
HP Mini 210 Hard Drive Replacement
你所需要的
  1. HP Mini 210 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP Mini 210 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. HP Mini 210 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the battery out from the netbook.
  3. HP Mini 210 Hard Drive Replacement, Disassembling HP Mini 210 Back Case: 步骤 3 中的图像 1,1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. HP Mini 210 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. HP Mini 210 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Pull the back case off from the front edge.
  6. HP Mini 210 Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Peel back the black sticker covering the hard drive with tweezers or your fingers.
  7. HP Mini 210 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Use a plastic opening tool to carefully disconnect the hard drive connector found above the RAM slot.
  8. HP Mini 210 Hard Drive Replacement: 步骤 8 中的图像 1,2 HP Mini 210 Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Pull the silver plastic tab up and remove the hard drive. The tab may also be black.
    • Be aware of the 4 foam cushions on each corner of the hard drive as they may become loose during removal.
结论
14等其他人完成本指南。
Heather Freed
于10/06/12注册
723 声望
创作了8篇指南
团队
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G17
3 名成员
创作了8篇指南
一条评论
Be aware that some models don't have buttons but a orange switch that need some pressure to release the cover
Alejandro - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 34
总计 18,147
