跳转到主内容
修复你的物品
维修的权力
商店
简介
If the hard drive makes scratching or whining noises, or if the operating system does not boot due to a disk read error, you may need to replace it.
The hard drive contains operating system files and your personal files. If you intend to replace the hard drive, save any personal files you need later onto an alternative media source before completing these steps. You will need to install an operating system on the new hard drive once the new hard drive is installed on the netbook.
  1. Turn off and unplug the netbook before replacing the battery. Hold the netbook top-side down with the lid closed.
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. Slide the battery out from the netbook.
    • Slide the battery out from the netbook.
  3. Turn the netbook to view its edge.
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  5. If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  6. Pull the back case off from the front edge.
    • Pull the back case off from the front edge.
  7. Peel back the black sticker covering the hard drive with tweezers or your fingers.
    • Peel back the black sticker covering the hard drive with tweezers or your fingers.
  8. Use a plastic opening tool to carefully disconnect the hard drive connector found above the RAM slot.
    • Use a plastic opening tool to carefully disconnect the hard drive connector found above the RAM slot.
  9. Pull the silver plastic tab up and remove the hard drive. The tab may also be black. Be aware of the 4 foam cushions on each corner of the hard drive as they may become loose during removal.
    • Pull the silver plastic tab up and remove the hard drive. The tab may also be black.
    • Be aware of the 4 foam cushions on each corner of the hard drive as they may become loose during removal.
结论
13等其他人完成本指南。
Heather Freed
于2012年10月06日注册
636 信誉积分
创作了8篇指南
团队
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G17
3 名成员
创作了8篇指南
Be aware that some models don't have buttons but a orange switch that need some pressure to release the cover
Alejandro - 回复
添加评论
浏览统计数据:
过去的24小时: 5
过去的7天: 19
过去的30天: 94
总计 16,360
