当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Turn off and unplug the netbook before replacing the battery.
Hold the netbook top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
Turn the netbook to view its edge.
Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
Cut one side of the black adhesive ribbon on top of the CMOS battery with a utility blade.
Be careful not to scratch or damage the battery or netbook, and be sure to keep your fingers out of the way!
Pop the CMOS battery out.
When reinstalling, insert the battery back into the slot with the positive terminal facing up.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
