跳转到主内容
修复你的物品
维修的权力
商店
简介
Replacing the battery in this netbook is quick and does not require any disassembly.
  1. Turn off and unplug the netbook before replacing the battery. Hold the netbook top-side down with the lid closed.
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. Slide the battery out from the netbook.
    • Slide the battery out from the netbook.
结论
6等其他人完成本指南。
Heather Freed
于2012年10月06日注册
636 信誉积分
创作了8篇指南
团队
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G17
3 名成员
创作了8篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 13
过去的30天: 29
总计 5,097
