跳转到主内容
HP Mini 110-3131dx Touchpad Replacement
你所需要的
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Touchpad Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Remove the three black screws marked by the keyboard symbol using a Phillips #1 screwdriver.
  2. HP Mini 110-3131dx Touchpad Replacement: 步骤 3 中的图像 1,3 HP Mini 110-3131dx Touchpad Replacement: 步骤 3 中的图像 2,3 HP Mini 110-3131dx Touchpad Replacement: 步骤 3 中的图像 3,3
    • Turn the laptop upright and open it.
    • Disconnect the clips located around the perimeter of the keyboard.
    • Slide the iFixit opening tool between the top edge of the keyboard and the plastic bezel.
    • Start either above the esc key or the delete key.
    • Pull the keyboard with your fingers until it comes out on both sides.
    • Be careful not to pull the keyboard out too fast. There is a fragile ribbon cable that attaches to the motherboard behind the keyboard.
  3. HP Mini 110-3131dx Touchpad Replacement: 步骤 4 中的图像 1,1
    • Tilt the keyboard toward you to reveal the ribbon cable.
    • Lift up the black tab on top of the keyboard ribbon cable to release the ribbon cable.
    • Pull the ribbon cable out of its container.
  4. HP Mini 110-3131dx Touchpad Replacement, Keyboard Bezel: 步骤 5 中的图像 1,2 HP Mini 110-3131dx Touchpad Replacement, Keyboard Bezel: 步骤 5 中的图像 2,2
    • Remove the six black screws around the perimeter of the laptop using a Phillips #1 screwdriver.
    • Be sure to keep track of which screws go where as they are not all the same size.
    • Flip the laptop over and remove the six black screws.
  5. HP Mini 110-3131dx Touchpad Replacement: 步骤 6 中的图像 1,2 HP Mini 110-3131dx Touchpad Replacement: 步骤 6 中的图像 2,2
    • Using your fingernail or the iFixit opening tool, flip the black tab up to release the ribbon cable that connects the touchpad and motherboard.
    • Disconnect the red and black wires from the motherboard on the left-hand side of the bezel using your fingernail or iFixit opening tool.
  6. HP Mini 110-3131dx Touchpad Replacement: 步骤 7 中的图像 1,1
    • Lift the keyboard bezel from the back end and slide the iFixit opening tool around the perimeter of the bezel until it is fully released.
  7. HP Mini 110-3131dx Touchpad Replacement, Touchpad: 步骤 8 中的图像 1,3 HP Mini 110-3131dx Touchpad Replacement, Touchpad: 步骤 8 中的图像 2,3 HP Mini 110-3131dx Touchpad Replacement, Touchpad: 步骤 8 中的图像 3,3
    • Turn the keyboard so that the touchpad is close to you.
    • Detach the ribbon cable from the connector on the touchpad circuit board using your fingernail or an opening tool.
    • Remove the four 2.9 mm screws from the bracket using a Phillips #0 screwdriver.
    • Remove the touchpad from the top of the keyboard bezel on the touch-sensitive side.
结论
另外一个人完成了本指南。
aarondcollege
于10/06/16注册
1,297 声望
创作了10篇指南
团队
USF Tampa, Team 2-4, Cagle Fall 2016 USF Tampa, Team 2-4, Cagle Fall 2016 的会员
USFT-CAGLE-F16S2G4
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 648
