跳转到主内容
HP Mini 110-3131dx Screen Replacement
你所需要的
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Screen Replacement, Screen: 步骤 2 中的图像 1,3 HP Mini 110-3131dx Screen Replacement, Screen: 步骤 2 中的图像 2,3 HP Mini 110-3131dx Screen Replacement, Screen: 步骤 2 中的图像 3,3
    • Slightly tilt the screen downward.
    • The screen is attached by internal clips and adhesive, which means that some force will be necessary for this step.
    • Use the plastic opening tool to force the screen bezel from the screen.
    • Locate the eight silver 2.9mm screws attaching the screen to the lid.
    • Using a PH1 philips head screwdriver detach the screws.
结论
另外一个人完成了本指南。
aarondcollege
于10/06/16注册
1,297 声望
创作了10篇指南
团队
USF Tampa, Team 2-4, Cagle Fall 2016 USF Tampa, Team 2-4, Cagle Fall 2016 的会员
USFT-CAGLE-F16S2G4
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 507
