跳转到主内容
HP Mini 110-3131dx Memory Card Replacement
你所需要的
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Memory Card Replacement, Back Cover: 步骤 2 中的图像 1,2 HP Mini 110-3131dx Memory Card Replacement, Back Cover: 步骤 2 中的图像 2,2
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Memory Card Replacement, Memory Card: 步骤 3 中的图像 1,3 HP Mini 110-3131dx Memory Card Replacement, Memory Card: 步骤 3 中的图像 2,3 HP Mini 110-3131dx Memory Card Replacement, Memory Card: 步骤 3 中的图像 3,3
    • Find the two silver screws that hold the memory card cover.
    • Take a PH1 screwdriver and unscrew the two screws.
    • Remove the metal cover
  3. HP Mini 110-3131dx Memory Card Replacement: 步骤 4 中的图像 1,2 HP Mini 110-3131dx Memory Card Replacement: 步骤 4 中的图像 2,2
    • Pull the two white tabs located on either side of the memory card away from each other until the card pops up
    • Remove the card
结论
To install the new memory card, follow these instructions in reverse order.
另外一个人完成了本指南。
aarondcollege
于10/06/16注册
1,297 声望
创作了10篇指南
团队
USF Tampa, Team 2-4, Cagle Fall 2016 USF Tampa, Team 2-4, Cagle Fall 2016 的会员
USFT-CAGLE-F16S2G4
5 名成员
创作了10篇指南
一条评论
what ram she using hp mini
ASKAR MALAYA - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 691
