跳转到主内容
HP Mini 110-1046NR Memory Card Replacement
你所需要的
  1. HP Mini 110-1046NR Memory Card Replacement, Battery: 步骤 1 中的图像 1,3 HP Mini 110-1046NR Memory Card Replacement, Battery: 步骤 1 中的图像 2,3 HP Mini 110-1046NR Memory Card Replacement, Battery: 步骤 1 中的图像 3,3
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
  2. HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: 步骤 2 中的图像 1,3 HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: 步骤 2 中的图像 2,3 HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: 步骤 2 中的图像 3,3
    • Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover.
    • Next, take a Phillips PH1 screwdriver and unscrew the two screws.
    • These screws will not release from the cover once they are unscrewed.
    • If necessary, use the flat end of the spudger to assist in prying the cover away from the computer.
  3. HP Mini 110-1046NR Memory Card Replacement, Memory Card: 步骤 3 中的图像 1,3 HP Mini 110-1046NR Memory Card Replacement, Memory Card: 步骤 3 中的图像 2,3 HP Mini 110-1046NR Memory Card Replacement, Memory Card: 步骤 3 中的图像 3,3
    • Carefully push the clips to the side, away from the memory card.
    • Note: The memory module is spring-loaded and will pop out when the clips are detatched.
    • Slide the memory card straight out, holding it as shown to avoid getting skin oils on the electrical contacts.
结论
2等其他人完成本指南。
Jared Cooper
于10/18/13注册
649 声望
创作了5篇指南
团队
Clemson, Team 14-1, Benson Fall 2013 Clemson, Team 14-1, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G1
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,321
