当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Power-off the netbook fully before attempting to remove the battery.
Flip your netbook upside down, and locate the sliding tabs near the battery.
Slide both tabs inward so that the battery visibly moves away from the case of the computer.
Release the tabs and pull the battery out.
这个步骤还没有翻译 帮忙翻译一下
Flip the netbook upright, and open the screen as far as it will go.
Pry up the keyboard from the middle of the top edge.
Insert the flat end of the spudger between middle of the the top edge of the keyboard and the plastic frame behind it.
Pry the keyboard up until it pops out or until you can grab it with your fingers, and then pull gently until it pops out on both sides.
这个步骤还没有翻译 帮忙翻译一下
Flip the keyboard over (toward you) by pivoting it about the lower edge, and lay it upside down on top of the touchpad area to reveal the ribbon cable.
Lightly pull up on the black tab on top of the keyboard ribbon cable until it hinges toward you and releases the ribbon cable end.
Pull the ribbon cable backward and out of the receptacle. This should not require any effort.
这个步骤还没有翻译 帮忙翻译一下
Remove the three screws holding down the hard drive. Use a Phillips PH0 screwdriver for the two silver, 3.4mm screws on the right, and use a PH1 for the black, 10.3mm screw on the left.
It is not necessary to fully remove the 10.3mm screw, but if you do, be careful to not lose the spring.
这个步骤还没有翻译 帮忙翻译一下
As shown on the top face of the hard drive itself, pull hard drive left using the black tab until the hard drive is unplugged and entirely released from its receptacle.
Lift the hard drive out of the laptop.
Place the hard drive in an anti-static bag to reduce the likelihood of damaging it with static electricity.
12等其他人完成本指南。
