跳转到主内容
加入维修社区 - 创建账户
HP Mini 1000 RAM Replacement
你所需要的
  1. HP Mini 1000 RAM Replacement, Battery: 步骤 1 中的图像 1,2 HP Mini 1000 RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • With the case closed, place the Mini 1000 top-side down on a flat surface.
    • Push both of the battery release latches toward each other.
  2. HP Mini 1000 RAM Replacement: 步骤 2 中的图像 1,1
    • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
  3. HP Mini 1000 RAM Replacement, RAM: 步骤 3 中的图像 1,2 HP Mini 1000 RAM Replacement, RAM: 步骤 3 中的图像 2,2
    • Before proceeding, slide the right battery release latch to the unlocked position nearest the center of the computer.
    • Use the tip of a spudger to slide the RAM compartment cover release latch away from the center of the computer.
    • At this point, the edge of the RAM compartment cover nearest the battery compartment should pop up from the lower case.
  4. HP Mini 1000 RAM Replacement: 步骤 4 中的图像 1,1
    • Remove the RAM compartment cover from the lower case.
  5. HP Mini 1000 RAM Replacement: 步骤 5 中的图像 1,2 HP Mini 1000 RAM Replacement: 步骤 5 中的图像 2,2
    • Use your fingers to simultaneously pull both RAM retaining arms away from the center of the RAM chip.
    • The RAM chip should pop up slightly from its socket.
    • Pull the RAM chip out of its socket and remove it from the Mini 1000.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 18
总计 4,689
