简介
Use this guide to replace a dead PRAM battery.
你所需要的
With the case closed, place the Mini 1000 top-side down on a flat surface.
Push both of the battery release latches toward each other.
Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket.
Pull the SIM card ribbon cable out of its socket and peel it off the top of the hard drive enclosure.
Using the sharp tip of a spudger, pry and remove the four plastic screw covers from the underside of the HP Mini 1000.
The two bottom covers are short in height and are notched to prevent incorrect insertion
The upper right cover is taller in height and is notched.
The upper left cover is taller in height and is not notched.
Wedge the flat end of a spudger in between the upper case and lower case near the bottom right corner of the display.
Carefully pry and rock the spudger upwards to create a small gap between the upper case and lower case.
Continue the previously described motion along the right edge of the upper case to release the clips securing the upper case to the lower case.
3等其他人完成本指南。
4条评论
Where can you find the replacement battery for this? do you take it apart and slide in a cr2016 watch battery?
Jake Stitt - 回复
Try eBay. If you can solder, it's best to get a CR1616 with tabs
whhere cann youu findd a replacement bbattery in 2018
Is there enough room to install a CR2020 or a CR2025?
