跳转到主内容
HP Mini 1000 Bluetooth Board Replacement
你所需要的
  1. HP Mini 1000 Bluetooth Board Replacement, Battery: 步骤 1 中的图像 1,2 HP Mini 1000 Bluetooth Board Replacement, Battery: 步骤 1 中的图像 2,2
    • With the case closed, place the Mini 1000 top-side down on a flat surface.
    • Push both of the battery release latches toward each other.
  2. HP Mini 1000 Bluetooth Board Replacement: 步骤 2 中的图像 1,1
    • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
  3. HP Mini 1000 Bluetooth Board Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Remove the following two screws:
    • One 6 mm Phillips screw
    • One 4 mm Phillips screw
  4. HP Mini 1000 Bluetooth Board Replacement: 步骤 4 中的图像 1,3 HP Mini 1000 Bluetooth Board Replacement: 步骤 4 中的图像 2,3 HP Mini 1000 Bluetooth Board Replacement: 步骤 4 中的图像 3,3
    • To facilitate the removal of the keyboard, it is recommended to push the keyboard outwards with one hand through the opening (highlighted in the third picture) located on the backside of the Mini 1000.
    • While pushing through the opening with one hand, grasp the left upper edge with the other hand and slightly pull the keyboard towards you.
    • Once an opening has been established, grasp the keyboard and slowly lift it upwards along the upper perimeter of the top edge.
  5. HP Mini 1000 Bluetooth Board Replacement: 步骤 5 中的图像 1,1
    • Lift the keyboard out of the upper case, minding the cable that is still connecting it to the motherboard.
  6. HP Mini 1000 Bluetooth Board Replacement: 步骤 6 中的图像 1,1
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the keyboard cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the cable out of its socket and remove the keyboard.
  7. HP Mini 1000 Bluetooth Board Replacement, Hard Drive: 步骤 7 中的图像 1,2 HP Mini 1000 Bluetooth Board Replacement, Hard Drive: 步骤 7 中的图像 2,2
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket.
    • Pull the SIM card ribbon cable out of its socket and peel it off the top of the hard drive enclosure.
  8. HP Mini 1000 Bluetooth Board Replacement: 步骤 8 中的图像 1,1
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the hard drive cable ZIF socket.
  9. HP Mini 1000 Bluetooth Board Replacement: 步骤 9 中的图像 1,1
    • Remove the two 4.5 mm Phillips screws securing the hard drive to the lower case.
  10. HP Mini 1000 Bluetooth Board Replacement: 步骤 10 中的图像 1,2 HP Mini 1000 Bluetooth Board Replacement: 步骤 10 中的图像 2,2
    • Lift the hard drive up and out of the lower case, being careful not to damage its cable in the process.
  11. HP Mini 1000 Bluetooth Board Replacement, Upper Case: 步骤 11 中的图像 1,1
    • Using the sharp tip of a spudger, pry and remove the four plastic screw covers from the underside of the HP Mini 1000.
    • There are three different variations of the covers:
    • The two bottom covers are short in height and are notched to prevent incorrect insertion
    • The upper right cover is taller in height and is notched.
    • The upper left cover is taller in height and is not notched.
  12. HP Mini 1000 Bluetooth Board Replacement: 步骤 12 中的图像 1,1
    • Remove the four 7 mm Phillips screws that secure the upper case to the lower case.
  13. HP Mini 1000 Bluetooth Board Replacement: 步骤 13 中的图像 1,1
    • Flip the computer over and open the display.
    • Remove the two 4.5 mm Phillips screws securing the upper case to the lower case.
  14. HP Mini 1000 Bluetooth Board Replacement: 步骤 14 中的图像 1,2 HP Mini 1000 Bluetooth Board Replacement: 步骤 14 中的图像 2,2
    • Wedge the flat end of a spudger in between the upper case and lower case near the bottom right corner of the display.
    • Carefully pry and rock the spudger upwards to create a small gap between the upper case and lower case.
    • Continue the previously described motion along the right edge of the upper case to release the clips securing the upper case to the lower case.
  15. HP Mini 1000 Bluetooth Board Replacement: 步骤 15 中的图像 1,2 HP Mini 1000 Bluetooth Board Replacement: 步骤 15 中的图像 2,2
    • Repeat the same procedure as mentioned in the previous step to release the clips along the left side of the upper case.
  16. HP Mini 1000 Bluetooth Board Replacement: 步骤 16 中的图像 1,1
    • Grasp the upper case and carefully lift it slightly upwards, freeing it from any remaining clips.
    • The upper case is still attached via the TouchPad ribbon cable that is connected to the motherboard. Do not remove it completely just yet.
  17. HP Mini 1000 Bluetooth Board Replacement: 步骤 17 中的图像 1,1
    • Lay the upper case on top of the upper portion of the motherboard.
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the TouchPad cable ZIF socket.
    • Pull the TouchPad ribbon cable out of its socket.
    • Remove the upper case from the HP Mini 1000.
  18. HP Mini 1000 Bluetooth Board Replacement, Bluetooth Board: 步骤 18 中的图像 1,1
    • If present, slightly peel back the large piece of black adhesive film covering the connector on the Bluetooth cable.
    • It is not necessary to completely remove the piece of film from the computer.
  19. HP Mini 1000 Bluetooth Board Replacement: 步骤 19 中的图像 1,2 HP Mini 1000 Bluetooth Board Replacement: 步骤 19 中的图像 2,2
    • While holding the film out of the way, use the flat end of a spudger to carefully lift the Bluetooth cable connector out of its socket on the motherboard.
    • Gently pry the Bluetooth board off the motherboard and remove it from the Mini 1000.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 3,266
