跳转到主内容
HP Media Center 876x Optical Drive Replacement
你所需要的
  1. HP Media Center 876x Optical Drive Replacement, Side Panel: 步骤 1 中的图像 1,2 HP Media Center 876x Optical Drive Replacement, Side Panel: 步骤 1 中的图像 2,2
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x Optical Drive Replacement: 步骤 2 中的图像 1,3 HP Media Center 876x Optical Drive Replacement: 步骤 2 中的图像 2,3 HP Media Center 876x Optical Drive Replacement: 步骤 2 中的图像 3,3
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x Optical Drive Replacement, Front Cover: 步骤 3 中的图像 1,2 HP Media Center 876x Optical Drive Replacement, Front Cover: 步骤 3 中的图像 2,2
    • Orient the tower vertically.
    • Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
    • Slide the side panel out of its notches, and pull it gently off of the tower.
  4. HP Media Center 876x Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Gently move the tower so that it is in the horizontal orientation.
    • Press down the black tabs (proximal to you) that fasten the front panel to the tower.
    • Press down on the distal, black tabs (symmetric with respect to the previous tabs).
    • Pull front panel forward slightly.
  5. HP Media Center 876x Optical Drive Replacement: 步骤 5 中的图像 1,2 HP Media Center 876x Optical Drive Replacement: 步骤 5 中的图像 2,2
    • The front panel will come off in a hinge-like fashion, exposing the drives underneath.
  6. HP Media Center 876x Optical Drive Replacement, Optical Drive: 步骤 6 中的图像 1,3 HP Media Center 876x Optical Drive Replacement, Optical Drive: 步骤 6 中的图像 2,3 HP Media Center 876x Optical Drive Replacement, Optical Drive: 步骤 6 中的图像 3,3
    • Identify the optical drive.
    • Pull the molex connectors out of the posterior end of the optical drive.
  7. HP Media Center 876x Optical Drive Replacement: 步骤 7 中的图像 1,3 HP Media Center 876x Optical Drive Replacement: 步骤 7 中的图像 2,3 HP Media Center 876x Optical Drive Replacement: 步骤 7 中的图像 3,3
    • Pull the ribbon cable out of the back of the optical drive.
  8. HP Media Center 876x Optical Drive Replacement: 步骤 8 中的图像 1,3 HP Media Center 876x Optical Drive Replacement: 步骤 8 中的图像 2,3 HP Media Center 876x Optical Drive Replacement: 步骤 8 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the two 5 mm screws that fasten the optical drive into its port.
    • Gently pull the optical drive through the front cavity.
  9. HP Media Center 876x Optical Drive Replacement: 步骤 9 中的图像 1,2 HP Media Center 876x Optical Drive Replacement: 步骤 9 中的图像 2,2
    • Remove the optical drive completely from its port.
结论
2等其他人完成本指南。
团队
Clemson, Team 6-1, Benson Spring 2014 Clemson, Team 6-1, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G1
3 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 361
