跳转到主内容
HP LaserJet P1102w Power Plug Replacement
你所需要的
  1. HP LaserJet P1102w Power Plug Replacement, Left Side Panel: 步骤 1 中的图像 1,3 HP LaserJet P1102w Power Plug Replacement, Left Side Panel: 步骤 1 中的图像 2,3 HP LaserJet P1102w Power Plug Replacement, Left Side Panel: 步骤 1 中的图像 3,3
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
  2. HP LaserJet P1102w Power Plug Replacement: 步骤 2 中的图像 1,2 HP LaserJet P1102w Power Plug Replacement: 步骤 2 中的图像 2,2
    • Now that the pry points are free lift up the front panel.
  3. HP LaserJet P1102w Power Plug Replacement: 步骤 3 中的图像 1,2 HP LaserJet P1102w Power Plug Replacement: 步骤 3 中的图像 2,2
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
  4. HP LaserJet P1102w Power Plug Replacement: 步骤 4 中的图像 1,3 HP LaserJet P1102w Power Plug Replacement: 步骤 4 中的图像 2,3 HP LaserJet P1102w Power Plug Replacement: 步骤 4 中的图像 3,3
    • Using the plastic spudger, remove the button housing from the top left of printer.
  5. HP LaserJet P1102w Power Plug Replacement: 步骤 5 中的图像 1,2 HP LaserJet P1102w Power Plug Replacement: 步骤 5 中的图像 2,2
    • Once the housing is removed, remove the three buttons.
  6. HP LaserJet P1102w Power Plug Replacement: 步骤 6 中的图像 1,3 HP LaserJet P1102w Power Plug Replacement: 步骤 6 中的图像 2,3 HP LaserJet P1102w Power Plug Replacement: 步骤 6 中的图像 3,3
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
  7. HP LaserJet P1102w Power Plug Replacement: 步骤 7 中的图像 1,2 HP LaserJet P1102w Power Plug Replacement: 步骤 7 中的图像 2,2
    • With all pry points free, remove the side panel.
  8. HP LaserJet P1102w Power Plug Replacement, Power Plug: 步骤 8 中的图像 1,2 HP LaserJet P1102w Power Plug Replacement, Power Plug: 步骤 8 中的图像 2,2
    • The power plug will be held together with one Phillips screw 7mm and wire connection.
  9. HP LaserJet P1102w Power Plug Replacement: 步骤 9 中的图像 1,2 HP LaserJet P1102w Power Plug Replacement: 步骤 9 中的图像 2,2
    • Unplug wire connector and unscrew the Phillips 7mm screw with #1 Phillips screw driver.
  10. HP LaserJet P1102w Power Plug Replacement: 步骤 10 中的图像 1,3 HP LaserJet P1102w Power Plug Replacement: 步骤 10 中的图像 2,3 HP LaserJet P1102w Power Plug Replacement: 步骤 10 中的图像 3,3
    • Apply pressure using spudger on top of the power plug to release it from metal housing. While doing that pull the power plug out.
结论
3等其他人完成本指南。
团队
UW Stout, Team S6-G4, Ogden Fall 2018 UW Stout, Team S6-G4, Ogden Fall 2018 的会员
UWSTOUT-OGDEN-F18S6G4
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 47
总计 1,608
