跳转到主内容
HP LaserJet P1102w Drive Belt Replacement
你所需要的
  1. HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: 步骤 1 中的图像 1,3 HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: 步骤 1 中的图像 2,3 HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: 步骤 1 中的图像 3,3
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
  2. HP LaserJet P1102w Drive Belt Replacement: 步骤 2 中的图像 1,2 HP LaserJet P1102w Drive Belt Replacement: 步骤 2 中的图像 2,2
    • Now that the pry points are free lift up the front panel.
  3. HP LaserJet P1102w Drive Belt Replacement: 步骤 3 中的图像 1,2 HP LaserJet P1102w Drive Belt Replacement: 步骤 3 中的图像 2,2
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
  4. HP LaserJet P1102w Drive Belt Replacement: 步骤 4 中的图像 1,3 HP LaserJet P1102w Drive Belt Replacement: 步骤 4 中的图像 2,3 HP LaserJet P1102w Drive Belt Replacement: 步骤 4 中的图像 3,3
    • Using the plastic spudger, remove the button housing from the top left of printer.
  5. HP LaserJet P1102w Drive Belt Replacement: 步骤 5 中的图像 1,2 HP LaserJet P1102w Drive Belt Replacement: 步骤 5 中的图像 2,2
    • Once the housing is removed, remove the three buttons.
  6. HP LaserJet P1102w Drive Belt Replacement: 步骤 6 中的图像 1,3 HP LaserJet P1102w Drive Belt Replacement: 步骤 6 中的图像 2,3 HP LaserJet P1102w Drive Belt Replacement: 步骤 6 中的图像 3,3
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
  7. HP LaserJet P1102w Drive Belt Replacement: 步骤 7 中的图像 1,2 HP LaserJet P1102w Drive Belt Replacement: 步骤 7 中的图像 2,2
    • With all pry points free, remove the side panel.
  8. HP LaserJet P1102w Drive Belt Replacement, Drive Belt: 步骤 8 中的图像 1,3 HP LaserJet P1102w Drive Belt Replacement, Drive Belt: 步骤 8 中的图像 2,3 HP LaserJet P1102w Drive Belt Replacement, Drive Belt: 步骤 8 中的图像 3,3
    • Refer to the prerequisite guide to take off the front panel off.
    • With a #1 Phillips screwdriver remove only the top Phillips 60mm screw.
    • With the spudger pry the side panel off. There will be four flanges to unhitch.
  9. HP LaserJet P1102w Drive Belt Replacement: 步骤 9 中的图像 1,2 HP LaserJet P1102w Drive Belt Replacement: 步骤 9 中的图像 2,2
    • With side panel removed, there will be four Phillips 60mm screws to unscrew using a #1 Phillips screwdriver.
  10. HP LaserJet P1102w Drive Belt Replacement: 步骤 10 中的图像 1,3 HP LaserJet P1102w Drive Belt Replacement: 步骤 10 中的图像 2,3 HP LaserJet P1102w Drive Belt Replacement: 步骤 10 中的图像 3,3
    • Remove top two big gears using tweezers.
    • Take note of gear placement.
  11. HP LaserJet P1102w Drive Belt Replacement: 步骤 11 中的图像 1,3 HP LaserJet P1102w Drive Belt Replacement: 步骤 11 中的图像 2,3 HP LaserJet P1102w Drive Belt Replacement: 步骤 11 中的图像 3,3
    • With the #1 Phillips screwdriver remove the 60mm Phillips screw holding the belt tension-er.
    • With the screw removed, pull tension-er out.
    • Use tweezers to remove the loose drive belt.
结论
6等其他人完成本指南。
Jerome Etten
于10/04/18注册
709 声望
创作了4篇指南
团队
UW Stout, Team S6-G4, Ogden Fall 2018 UW Stout, Team S6-G4, Ogden Fall 2018 的会员
UWSTOUT-OGDEN-F18S6G4
4 名成员
创作了10篇指南
一条评论
the tight side panel clips make this a difficult procedure, so take care both disassembling and assembling, for example make sure the power button is aligned with the level components behind before you push to clip the front home, as misalignment can break or dislocate internal parts.
Peter Taffs - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 44
总计 2,751
