跳转到主内容
HP LaserJet 5M Laser Printer Maintenance Kit and Exit rollers Replacement
你所需要的
    • Unplug the printer, open the back door, remove the two screws down low which hold the fuser assembly in place. ( Screws are silver) Grab the fuser and pull out in an upward direction, put fuser aside. Grab your new fuser and reverse the procedure, fuser will click into place and the screw holes will line up.
    • New line.
    • Install the two silver screws back in there holes. Now while the back rear door is open, look for the two screws in the right and left corners and remove them. Open the top toner cartridge door and remove the toner. On the top cover, remove the one silver screw, you can now lift the top off the printer, make sure you unplug the display cable as you
    • lift the top cover off. Focus on the rear of printer once more, push in on the exit roller clips ( at the base of the exit/ delivery ass'y ) and lift the exit / delivery assembly off, as you carefully remove the silver clip on the right side. Remove the two worn rollers from the exit/ delivery assembly and reinstall the new rollers. Reinstall....
结论
2等其他人完成本指南。
团队
GMS Lazerworks GMS Lazerworks 的会员
Business
1 名成员
创作了2篇指南
一条评论
Output assembly removal: (1) Remove the top cover (3 screws) and the right cover (2 tabs); (2) Open the rear access door and let in hang open; (3) The output assembly has 2 press-in plastic tabs which you press in while lifting and rotating the output assembly away from you and toward the front of the printer. The output assembly is thus removed.
L. Schwartz - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 483
