跳转到主内容
HP LaserJet 1160 or 1320 Main Motor Replacement
你所需要的
  1. HP LaserJet 1160 or 1320 Main Motor Replacement, Left Side Cover: 步骤 1 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Left Side Cover: 步骤 1 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Left Side Cover: 步骤 1 中的图像 3,3
    • Pull on the two tabs on the back of the printer to release the left side cover.
    • Remove the cover by rotating it towards the front of the printer.
  2. HP LaserJet 1160 or 1320 Main Motor Replacement, Right Side Cover: 步骤 2 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Right Side Cover: 步骤 2 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Right Side Cover: 步骤 2 中的图像 3,3
    • With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
    • Lift the cover off of the printer.
  3. HP LaserJet 1160 or 1320 Main Motor Replacement, Back Cover: 步骤 3 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Back Cover: 步骤 3 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Back Cover: 步骤 3 中的图像 3,3
    • Remove 4 screws on the back of the printer.
    • Remove the back cover.
  4. HP LaserJet 1160 or 1320 Main Motor Replacement, Top Cover: 步骤 4 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Top Cover: 步骤 4 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Top Cover: 步骤 4 中的图像 3,3
    • Remove 2 screws on the back of the printer, one on the left, and one on the front.
    • The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
  5. HP LaserJet 1160 or 1320 Main Motor Replacement, Top Cover: 步骤 5 中的图像 1,1
    • Disconnect the control panel cable and remove the top cover.
  6. HP LaserJet 1160 or 1320 Main Motor Replacement, Fan: 步骤 6 中的图像 1,2 HP LaserJet 1160 or 1320 Main Motor Replacement, Fan: 步骤 6 中的图像 2,2
    • Disconnect the fan cable from the main board of the printer.
    • Remove the retaining clip holding the fan in.
    • Remove the 2 screws holding the fan in.
  7. HP LaserJet 1160 or 1320 Main Motor Replacement, Fan Cable: 步骤 7 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fan Cable: 步骤 7 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fan Cable: 步骤 7 中的图像 3,3
    • Remove the fan cable from the cable guide.
  8. HP LaserJet 1160 or 1320 Main Motor Replacement, Duplexer PCB: 步骤 8 中的图像 1,2 HP LaserJet 1160 or 1320 Main Motor Replacement, Duplexer PCB: 步骤 8 中的图像 2,2
    • Disconnect one cable from the main board of the printer.
    • Disconnect the duplexer solenoid cable from the duplexer PCB.
    • Remove one screw on the duplexer PCB and remove the PCB from the printer.
  9. HP LaserJet 1160 or 1320 Main Motor Replacement, Duplexer Gears: 步骤 9 中的图像 1,2 HP LaserJet 1160 or 1320 Main Motor Replacement, Duplexer Gears: 步骤 9 中的图像 2,2
    • Remove 3 screws holding the duplexer gears to the printer and remove the gears.
  10. HP LaserJet 1160 or 1320 Main Motor Replacement, Duplexer Solenoid: 步骤 10 中的图像 1,1
    • Remove one screw to remove the solenoid from the printer.
  11. HP LaserJet 1160 or 1320 Main Motor Replacement, Left Side Cover: 步骤 11 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Left Side Cover: 步骤 11 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Left Side Cover: 步骤 11 中的图像 3,3
  12. HP LaserJet 1160 or 1320 Main Motor Replacement, Formatter: 步骤 12 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Formatter: 步骤 12 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Formatter: 步骤 12 中的图像 3,3
    • Remove 2 screws on the I/O port cover.
    • Remove 6 screws on the formatter.
    • Disconnect 3 connectors from the formatter.
    • Disconnect 2 flat flexible cables from the formatter.
    • Remove the formatter from the printer.
    • Be careful not to fold, crease, or tear flat flexible cables.
    • The I/O port cover will need to be transferred to the new formatter before installing it.
  13. HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Gear: 步骤 13 中的图像 1,2 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Gear: 步骤 13 中的图像 2,2
    • Remove the fuser gear by pushing in on the tab with a metal spudger.
  14. HP LaserJet 1160 or 1320 Main Motor Replacement, Tray Connector: 步骤 14 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Tray Connector: 步骤 14 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Tray Connector: 步骤 14 中的图像 3,3
    • Disconnect the cable to the tray connector and route it through the hole in the chassis.
  15. HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: 步骤 15 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: 步骤 15 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: 步骤 15 中的图像 3,3
    • Disconnect 2 cables from the main board and route them through the cable guide.
  16. HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: 步骤 16 中的图像 1,2 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: 步骤 16 中的图像 2,2
    • Remove the cable guide from the chassis.
  17. HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: 步骤 17 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: 步骤 17 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: 步骤 17 中的图像 3,3
    • Remove the cable guide from the other side of the chassis.
    • Disconnect 2 cables from the main board.
  18. HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: 步骤 18 中的图像 1,2 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: 步骤 18 中的图像 2,2
    • Use needle nose pliers to disconnect the high voltage wire from the fuser.
  19. HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: 步骤 19 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: 步骤 19 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: 步骤 19 中的图像 3,3
    • Remove the tray connector cable from the cable guide.
    • Disconnect the main motor cable.
  20. HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser: 步骤 20 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser: 步骤 20 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser: 步骤 20 中的图像 3,3
    • Remove 3 screws from the right side of the printer.
    • Remove 3 screws from the left side of the printer.
    • The fuser assembly can now be removed from the printer.
  21. HP LaserJet 1160 or 1320 Main Motor Replacement, Midframe: 步骤 21 中的图像 1,2 HP LaserJet 1160 or 1320 Main Motor Replacement, Midframe: 步骤 21 中的图像 2,2
    • Remove 4 screws from each side of the printer to remove the mainframe.
  22. HP LaserJet 1160 or 1320 Main Motor Replacement, Safety Interlock Assembly: 步骤 22 中的图像 1,1
    • Remove 3 screws from the safety interlock assembly (one on top) and remove it from the printer.
  23. HP LaserJet 1160 or 1320 Main Motor Replacement, Feed Plate: 步骤 23 中的图像 1,2 HP LaserJet 1160 or 1320 Main Motor Replacement, Feed Plate: 步骤 23 中的图像 2,2
    • Remove the feed plate from over the main board.
  24. HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board Cables: 步骤 24 中的图像 1,2 HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board Cables: 步骤 24 中的图像 2,2
    • Remove the tray connector and motor cables from the cable guide.
  25. HP LaserJet 1160 or 1320 Main Motor Replacement, Cable Guide: 步骤 25 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Cable Guide: 步骤 25 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Cable Guide: 步骤 25 中的图像 3,3
    • Remove one screw from the cable guide and remove the cable guide from the chassis.
    • Remove one screw from the chassis.
  26. HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board: 步骤 26 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board: 步骤 26 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board: 步骤 26 中的图像 3,3
    • Remove 2 screws from the left side of the chassis.
    • Push the formatter and safety interlock cables through the hole in the chassis.
  27. HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board: 步骤 27 中的图像 1,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board: 步骤 27 中的图像 2,3 HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board: 步骤 27 中的图像 3,3
    • Bend the chassis to allow the control board to come loose, and disconnect the 2 cables from the paper feed assembly.
    • Remove the main board from the printer.
  28. HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board: 步骤 28 中的图像 1,1
    • Remove 4 screws on the control board to remove it from its metal plate.
  29. HP LaserJet 1160 or 1320 Main Motor Replacement, Main Motor: 步骤 29 中的图像 1,2 HP LaserJet 1160 or 1320 Main Motor Replacement, Main Motor: 步骤 29 中的图像 2,2
    • Remove 3 screws to remove the main motor.
结论
jdp23
于08/22/13注册
1,312 声望
创作了23篇指南
一条评论
hp 1320 printer not running
khurram shahzad - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 14
总计 1,380
