跳转到主内容
HP LaserJet 1160 or 1320 Laser Assembly Replacement
你所需要的
  1. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Left Side Cover: 步骤 1 中的图像 1,3 HP LaserJet 1160 or 1320 Laser Assembly Replacement, Left Side Cover: 步骤 1 中的图像 2,3 HP LaserJet 1160 or 1320 Laser Assembly Replacement, Left Side Cover: 步骤 1 中的图像 3,3
    • Pull on the two tabs on the back of the printer to release the left side cover.
    • Remove the cover by rotating it towards the front of the printer.
  2. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Right Side Cover: 步骤 2 中的图像 1,3 HP LaserJet 1160 or 1320 Laser Assembly Replacement, Right Side Cover: 步骤 2 中的图像 2,3 HP LaserJet 1160 or 1320 Laser Assembly Replacement, Right Side Cover: 步骤 2 中的图像 3,3
    • With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
    • Lift the cover off of the printer.
  3. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Back Cover: 步骤 3 中的图像 1,3 HP LaserJet 1160 or 1320 Laser Assembly Replacement, Back Cover: 步骤 3 中的图像 2,3 HP LaserJet 1160 or 1320 Laser Assembly Replacement, Back Cover: 步骤 3 中的图像 3,3
    • Remove 4 screws on the back of the printer.
    • Remove the back cover.
  4. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Top Cover: 步骤 4 中的图像 1,3 HP LaserJet 1160 or 1320 Laser Assembly Replacement, Top Cover: 步骤 4 中的图像 2,3 HP LaserJet 1160 or 1320 Laser Assembly Replacement, Top Cover: 步骤 4 中的图像 3,3
    • Remove 2 screws on the back of the printer, one on the left, and one on the front.
    • The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
  5. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Top Cover: 步骤 5 中的图像 1,1
    • Disconnect the control panel cable and remove the top cover.
  6. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Laser Assembly: 步骤 6 中的图像 1,3 HP LaserJet 1160 or 1320 Laser Assembly Replacement, Laser Assembly: 步骤 6 中的图像 2,3 HP LaserJet 1160 or 1320 Laser Assembly Replacement, Laser Assembly: 步骤 6 中的图像 3,3
    • Remove one cable from the top of the laser assembly and one cable from the right side of the laser assembly.
    • Remove 4 screws from the laser assembly.
    • Remove all cables from the cable clip on the side of the laser assembly and remove it from the printer.
结论
jdp23
于08/22/13注册
1,312 声望
创作了23篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 516
