跳转到主内容
HP HDX 16-1160US Wifi Card Replacement
你所需要的
  1. HP HDX 16-1160US Wifi Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US Wifi Card Replacement: 步骤 2 中的图像 1,3 HP HDX 16-1160US Wifi Card Replacement: 步骤 2 中的图像 2,3 HP HDX 16-1160US Wifi Card Replacement: 步骤 2 中的图像 3,3
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US Wifi Card Replacement: 步骤 3 中的图像 1,1
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US Wifi Card Replacement, Wifi Card: 步骤 4 中的图像 1,2 HP HDX 16-1160US Wifi Card Replacement, Wifi Card: 步骤 4 中的图像 2,2
    • Use the Phillips #1 Screw Driver to unscrew the 6mm screw from the Wi-Fi Card Panel.
    • The 6mm screw will remain in the Wi-Fi card panel and will not fall out.
    • Lift off the Wi-Fi card panel off using the opposite hand.
  5. HP HDX 16-1160US Wifi Card Replacement: 步骤 5 中的图像 1,2 HP HDX 16-1160US Wifi Card Replacement: 步骤 5 中的图像 2,2
    • Remove the gray and black wires by gently pulling up on them so that they "unsnap" from the Wi-Fi card.
  6. HP HDX 16-1160US Wifi Card Replacement: 步骤 6 中的图像 1,1
    • Remove the two 4mm screws with the Phillips #1 screw driver.
  7. HP HDX 16-1160US Wifi Card Replacement: 步骤 7 中的图像 1,1
    • Carefully use the plastic opening tools to lift the Wi-Fi card up on the left side.
    • Using the opposite hand, pull the Wi-Fi card to the left.
    • Do not lift the Wi-Fi card straight up, this will damage or break the Wi-Fi card.
结论
2等其他人完成本指南。
Marshall Reid
于04/14/14注册
527 声望
创作了3篇指南
团队
Cal Poly, Team 12-38, Maness Spring 2014 Cal Poly, Team 12-38, Maness Spring 2014 的会员
CPSU-MANESS-S14S12G38
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 1,138
