跳转到主内容
HP HDX 16-1160US DVD Drive Replacement
你所需要的
  1. HP HDX 16-1160US DVD Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US DVD Drive Replacement: 步骤 2 中的图像 1,3 HP HDX 16-1160US DVD Drive Replacement: 步骤 2 中的图像 2,3 HP HDX 16-1160US DVD Drive Replacement: 步骤 2 中的图像 3,3
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US DVD Drive Replacement: 步骤 3 中的图像 1,1
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US DVD Drive Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Remove the three 4mm screws using Phillips #1 screw driver.
    • Remove the four 6mm screws using Phillips #1 screw driver.
    • Remove the two 3mm screws using Phillips #1 screw driver.
  5. HP HDX 16-1160US DVD Drive Replacement: 步骤 5 中的图像 1,1
    • Using your fingers, pry off the speaker cover.
  6. HP HDX 16-1160US DVD Drive Replacement: 步骤 6 中的图像 1,3 HP HDX 16-1160US DVD Drive Replacement: 步骤 6 中的图像 2,3 HP HDX 16-1160US DVD Drive Replacement: 步骤 6 中的图像 3,3
    • Use the plastic opener to pry up the chrome keyboard cover from the lab top itself. Carefully work around the edges by prying each snap individually.
    • Remove the chrome keyboard cover.
    • Be careful not to pull the chrome cover completely off because there is a black strip connecting it to the laptop itself.
  7. HP HDX 16-1160US DVD Drive Replacement: 步骤 7 中的图像 1,3 HP HDX 16-1160US DVD Drive Replacement: 步骤 7 中的图像 2,3 HP HDX 16-1160US DVD Drive Replacement: 步骤 7 中的图像 3,3
    • Locate and remove the two 4mm screws with the Phillips #1 screw driver.
  8. HP HDX 16-1160US DVD Drive Replacement: 步骤 8 中的图像 1,2 HP HDX 16-1160US DVD Drive Replacement: 步骤 8 中的图像 2,2
    • Using your hands, pull the keyboard out.
    • Do not pull completely off because there is a grey strip connecting it to the laptop itself.
  9. HP HDX 16-1160US DVD Drive Replacement: 步骤 9 中的图像 1,2 HP HDX 16-1160US DVD Drive Replacement: 步骤 9 中的图像 2,2
    • Lift the black tab using the plastic opening tool.
    • Gently pull the grey strip out, horizontally way from you. This will release the keyboard from the computer.
  10. HP HDX 16-1160US DVD Drive Replacement, DVD Drive: 步骤 10 中的图像 1,1
    • Use the Phillips #1 Screw Driver to unscrew the 5mm screw.
  11. HP HDX 16-1160US DVD Drive Replacement: 步骤 11 中的图像 1,1
    • Flip over the device so that the bottom side is facing up.
    • Use the Phillips #1 Screw Driver to unscrew the 7mm screw near the center of the device.
  12. HP HDX 16-1160US DVD Drive Replacement: 步骤 12 中的图像 1,1
    • Push down and pull out the DVD on the left side of the device.
结论
3等其他人完成本指南。
Marshall Reid
于04/14/14注册
527 声望
创作了3篇指南
团队
Cal Poly, Team 12-38, Maness Spring 2014 Cal Poly, Team 12-38, Maness Spring 2014 的会员
CPSU-MANESS-S14S12G38
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,437
