跳转到主内容
HP G71t-400 WiFi Card Replacement
你所需要的
  1. HP G71t-400 WiFi Card Replacement, WiFi Card: 步骤 1 中的图像 1,3 HP G71t-400 WiFi Card Replacement, WiFi Card: 步骤 1 中的图像 2,3 HP G71t-400 WiFi Card Replacement, WiFi Card: 步骤 1 中的图像 3,3
    • Lay the laptop down so the bottom is facing up.
    • Push the slide button, circled in photo 1, to release the battery.
    • Action in picture 2 shows the direction and release.
    • Tilt the battery back in the direction it popped up in and remove the battery.
    • This ensures there is no power in the system that could potentially short out any components.
  2. HP G71t-400 WiFi Card Replacement: 步骤 2 中的图像 1,3 HP G71t-400 WiFi Card Replacement: 步骤 2 中的图像 2,3 HP G71t-400 WiFi Card Replacement: 步骤 2 中的图像 3,3
    • Remove the only circled screw.
    • Lift and remove the cover exposing the WiFi card.
  3. HP G71t-400 WiFi Card Replacement: 步骤 3 中的图像 1,1
    • Disconnect the two wires attached. Making note to where each wire was connected for easy install.
    • Extract the WiFi card.
结论
Nicholas Castro
于03/24/19注册
711 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 88
