跳转到主内容
HP G71t-400 Cooling Fan Replacement
你所需要的
  1. HP G71t-400 Cooling Fan Replacement, Cooling Fan: 步骤 1 中的图像 1,3 HP G71t-400 Cooling Fan Replacement, Cooling Fan: 步骤 1 中的图像 2,3 HP G71t-400 Cooling Fan Replacement, Cooling Fan: 步骤 1 中的图像 3,3
    • Lay the laptop down so the bottom is facing up.
    • Push the slide button, circled in photo 1, to release the battery.
    • Action in picture 2 shows the direction and release.
    • Tilt the battery back in the direction it popped up in and remove the battery.
    • This ensures there is no power in the system that could potentially short out any components.
  2. HP G71t-400 Cooling Fan Replacement: 步骤 2 中的图像 1,3 HP G71t-400 Cooling Fan Replacement: 步骤 2 中的图像 2,3 HP G71t-400 Cooling Fan Replacement: 步骤 2 中的图像 3,3
    • Remove the circled screws.
    • Remove the cover, exposing the hard drive and RAM.
  3. HP G71t-400 Cooling Fan Replacement: 步骤 3 中的图像 1,3 HP G71t-400 Cooling Fan Replacement: 步骤 3 中的图像 2,3 HP G71t-400 Cooling Fan Replacement: 步骤 3 中的图像 3,3
    • Remove the 2 circled screws.
    • Use your pry to slide the hard drive over. This unplugs it from its connection and allows it to be removed.
    • Remove the hard drive.
  4. HP G71t-400 Cooling Fan Replacement: 步骤 4 中的图像 1,2 HP G71t-400 Cooling Fan Replacement: 步骤 4 中的图像 2,2
    • Push the silver tabs in to release the RAM.
    • When they pop up from the locked position they may be removed.
    • Remove the circled screws to release the WiFi card and keyboard.
  5. HP G71t-400 Cooling Fan Replacement: 步骤 5 中的图像 1,3 HP G71t-400 Cooling Fan Replacement: 步骤 5 中的图像 2,3 HP G71t-400 Cooling Fan Replacement: 步骤 5 中的图像 3,3
    • Remove the panel, exposing the WiFi card.
    • Remove the circle wire connections, make note to which port they were connected to.
    • Remove the WiFi card.
  6. HP G71t-400 Cooling Fan Replacement: 步骤 6 中的图像 1,3 HP G71t-400 Cooling Fan Replacement: 步骤 6 中的图像 2,3 HP G71t-400 Cooling Fan Replacement: 步骤 6 中的图像 3,3
    • Flip the laptop over and open it now that the keyboard has been unscrewed.
    • Take your pry bar and go around the outer edge of the keyboard. Popping it free from the bezel.
  7. HP G71t-400 Cooling Fan Replacement: 步骤 7 中的图像 1,3 HP G71t-400 Cooling Fan Replacement: 步骤 7 中的图像 2,3 HP G71t-400 Cooling Fan Replacement: 步骤 7 中的图像 3,3
    • Lift the keyboard up.
    • Remove the connections from the keyboard to the motherboard.
    • Remember each attachments position because they will need to be connected again.
  8. HP G71t-400 Cooling Fan Replacement: 步骤 8 中的图像 1,3 HP G71t-400 Cooling Fan Replacement: 步骤 8 中的图像 2,3 HP G71t-400 Cooling Fan Replacement: 步骤 8 中的图像 3,3
    • Remove the circled screws to release the bezel from the faceplate.
  9. HP G71t-400 Cooling Fan Replacement: 步骤 9 中的图像 1,2 HP G71t-400 Cooling Fan Replacement: 步骤 9 中的图像 2,2
    • Lift the bezel from the face plate.
    • Disconnect the power connection from the bezel to the motherboard.
  10. HP G71t-400 Cooling Fan Replacement: 步骤 10 中的图像 1,3 HP G71t-400 Cooling Fan Replacement: 步骤 10 中的图像 2,3 HP G71t-400 Cooling Fan Replacement: 步骤 10 中的图像 3,3
    • Remove the two screws side-by-side next to each in the red circle.
    • This will be the last layer to remove before reaching the motherboard.
  11. HP G71t-400 Cooling Fan Replacement: 步骤 11 中的图像 1,2 HP G71t-400 Cooling Fan Replacement: 步骤 11 中的图像 2,2
    • Carefully detach the highlighted connections.
    • Remove the motherboard from the device.
  12. HP G71t-400 Cooling Fan Replacement: 步骤 12 中的图像 1,3 HP G71t-400 Cooling Fan Replacement: 步骤 12 中的图像 2,3 HP G71t-400 Cooling Fan Replacement: 步骤 12 中的图像 3,3
    • Remove three screws to detach the cooling fan from the motherboard.
    • Remove the last connection.
结论
Nicholas Castro
于03/24/19注册
711 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 137
