简介
Make sure that you have a cooling fan with the same voltage/amperage settings to prevent abnormal operation.
你所需要的
Ground yourself by either touching an unpainted metal surface or by using the Anti-Static wrist strap.
Turn off the computer and remove the charger from the charging port.
Turn the laptop over and slide the battery release catch to the right. The battery will pop up from its slot. Remove it using your fingers.
Use a Phillips #0 screwdriver to remove the 6mm screw from the top panel.
Gently lift and remove the panel. Use a metal spudger if the it seems set in place.
