跳转到主内容
HP G62-223CL Wireless Card Replacement
你所需要的
  1. HP G62-223CL Wireless Card Replacement, Battery Removal: 步骤 1 中的图像 1,2 HP G62-223CL Wireless Card Replacement, Battery Removal: 步骤 1 中的图像 2,2
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL Wireless Card Replacement, Wireless Card: 步骤 3 中的图像 1,2 HP G62-223CL Wireless Card Replacement, Wireless Card: 步骤 3 中的图像 2,2
    • Locate three Phillips head retaining screws which secure the compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL Wireless Card Replacement: 步骤 4 中的图像 1,3 HP G62-223CL Wireless Card Replacement: 步骤 4 中的图像 2,3 HP G62-223CL Wireless Card Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to disconnect the gray cable and the black cable from the wireless card.
  5. HP G62-223CL Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the single 4mm screw from the corner of the wireless card.
  6. HP G62-223CL Wireless Card Replacement: 步骤 6 中的图像 1,1
    • Carefully lift and pull wireless card. It is removed!
结论
Garret Layton
于01/13/15注册
669 声望
创作了5篇指南
团队
USF Tampa, Team 1-4, Sullivan Winter 2015 USF Tampa, Team 1-4, Sullivan Winter 2015 的会员
USFT-SULLIVAN-W15S1G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 1,090
