跳转到主内容
HP G62-144DX RAM Replacement
你所需要的
  1. HP G62-144DX RAM Replacement, Battery: 步骤 1 中的图像 1,2 HP G62-144DX RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX RAM Replacement, RAM: 步骤 2 中的图像 1,3 HP G62-144DX RAM Replacement, RAM: 步骤 2 中的图像 2,3 HP G62-144DX RAM Replacement, RAM: 步骤 2 中的图像 3,3
    • Unscrew the three Phillips 2.5x6 screws in the L-shaped panel on the back with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but will come loose from the body of the laptop.
    • Use a plastic opening tool to gently pry the panel free from the laptop.
  3. HP G62-144DX RAM Replacement: 步骤 3 中的图像 1,3 HP G62-144DX RAM Replacement: 步骤 3 中的图像 2,3 HP G62-144DX RAM Replacement: 步骤 3 中的图像 3,3
    • Pull the two metal clips to the top RAM module outwards parallel to the laptop.
    • After the RAM module pops up, gently pull in out from the computer.
    • Repeat for the second RAM module.
结论
Cameron Moran
于10/18/17注册
623 声望
创作了5篇指南
团队
UMass Dartmouth, Team S4-G8, Julie Fall 2017 UMass Dartmouth, Team S4-G8, Julie Fall 2017 的会员
UMASSD-JULIE-F17S4G8
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 345
