跳转到主内容
HP G62-144DX Keyboard Replacement
你所需要的
  1. HP G62-144DX Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 HP G62-144DX Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Remove the 3 Phillips 2.5x5 screws (closest to the battery slot) and the 2 Phillips 2.5x6.5 screws with a Phillips #1 screwdriver.
    • This screws will have a keyboard symbol inscribed next to them.
  3. HP G62-144DX Keyboard Replacement: 步骤 3 中的图像 1,3 HP G62-144DX Keyboard Replacement: 步骤 3 中的图像 2,3 HP G62-144DX Keyboard Replacement: 步骤 3 中的图像 3,3
    • Use the Phillips # 1 screwdriver to unscrew the 2.5x6 Phillips screws holding the L-shaped back panel.
    • Screws should stay in panel, but come free of the laptop body.
    • Gently use a plastic opening tool to remove the panel.
  4. HP G62-144DX Keyboard Replacement: 步骤 4 中的图像 1,2 HP G62-144DX Keyboard Replacement: 步骤 4 中的图像 2,2
    • Unscrew the final Phillips 2.5x5 keyboard screw with a Phillips #1 screwdriver.
  5. HP G62-144DX Keyboard Replacement: 步骤 5 中的图像 1,2 HP G62-144DX Keyboard Replacement: 步骤 5 中的图像 2,2
    • Flip the laptop so the top is facing up again and open the cover.
    • Use a metal spudger to pry the keyboard up and pull it back.
    • Be sure to pry up the board itself and not an individual key.
    • This process has the risk of breaking keys.
  6. HP G62-144DX Keyboard Replacement: 步骤 6 中的图像 1,2 HP G62-144DX Keyboard Replacement: 步骤 6 中的图像 2,2
    • Pull up the latch that connects the keyboard connector the the motherboard.
结论
2等其他人完成本指南。
Cameron Moran
于10/18/17注册
623 声望
创作了5篇指南
团队
UMass Dartmouth, Team S4-G8, Julie Fall 2017 UMass Dartmouth, Team S4-G8, Julie Fall 2017 的会员
UMASSD-JULIE-F17S4G8
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 619
