跳转到主内容
HP G62 347NR Keyboard Replacement
你所需要的
  1. HP G62 347NR Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR Keyboard Replacement: 步骤 3 中的图像 1,2 HP G62 347NR Keyboard Replacement: 步骤 3 中的图像 2,2
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR Keyboard Replacement: 步骤 4 中的图像 1,2 HP G62 347NR Keyboard Replacement: 步骤 4 中的图像 2,2
    • Locate the three Phillips head screws on the compartment with the wifi and keyboard logos.
    • Using the Phillips #1 screwdriver, remove the three screws.
  5. HP G62 347NR Keyboard Replacement: 步骤 5 中的图像 1,2 HP G62 347NR Keyboard Replacement: 步骤 5 中的图像 2,2
    • Locate the two keyboard logos on back of the computer.
    • Find the Phillips head screws in the hole next to the logo.
    • Remove the two screws using a Phillips #1 screwdriver.
  6. HP G62 347NR Keyboard Replacement: 步骤 6 中的图像 1,2 HP G62 347NR Keyboard Replacement: 步骤 6 中的图像 2,2
    • In the battery compartment, locate the three keyboard logos.
    • Find the Phillips head screws next to each logo.
    • Remove the three screws using the Phillips #1 screwdriver.
  7. HP G62 347NR Keyboard Replacement: 步骤 7 中的图像 1,2 HP G62 347NR Keyboard Replacement: 步骤 7 中的图像 2,2
    • Place the plastic opening tool between the keyboard and the motherboard.
    • Gently pry the entire keyboard up and away from the laptop's motherboard.
    • Once you have part of the keyboard separated, run your fingers around the edge of the keyboard to separate the entire thing.
结论
3等其他人完成本指南。
McKenzi Morris
于10/10/16注册
511 声望
创作了3篇指南
团队
Texas Tech, Team 6-1, Bennett Fall 2016 Texas Tech, Team 6-1, Bennett Fall 2016 的会员
TTU-BENNETT-F16S6G1
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 2,770
