跳转到主内容
HP G62 347NR Battery Replacement
你所需要的
  1. HP G62 347NR Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the battery, carefully, from the compartment.
结论
2等其他人完成本指南。
McKenzi Morris
于10/10/16注册
511 声望
创作了3篇指南
团队
Texas Tech, Team 6-1, Bennett Fall 2016 Texas Tech, Team 6-1, Bennett Fall 2016 的会员
TTU-BENNETT-F16S6G1
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 490
