跳转到主内容
HP G62 347NR CD/DVD Drive Replacement
你所需要的
  1. HP G62 347NR  CD/DVD Drive Replacement, CD/DVD Drive: 步骤 1 中的图像 1,1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR  CD/DVD Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR  CD/DVD Drive Replacement: 步骤 3 中的图像 1,1
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR  CD/DVD Drive Replacement: 步骤 4 中的图像 1,1
    • On the far left of the hard drive compartment, find the Phillips head screw.
    • Remove the Phillips head screw with the PH1 screwdriver.
  5. HP G62 347NR  CD/DVD Drive Replacement: 步骤 5 中的图像 1,2 HP G62 347NR  CD/DVD Drive Replacement: 步骤 5 中的图像 2,2
    • Get the plastic opening tool and place it between the laptop and the CD/DVD drive. Place it toward the center of the drive for maximum support.
    • Carefully pry the CD/DVD drive open.
    • Slide the CD/DVD drive out once it is pried open.
结论
McKenzi Morris
于10/10/16注册
511 声望
创作了3篇指南
团队
Texas Tech, Team 6-1, Bennett Fall 2016 Texas Tech, Team 6-1, Bennett Fall 2016 的会员
TTU-BENNETT-F16S6G1
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 547
