跳转到主内容
HP G60T-600 CTO Hard drive Replacement
你所需要的
  1. HP G60T-600 CTO Hard drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. HP G60T-600 CTO Hard drive Replacement: 步骤 2 中的图像 1,2 HP G60T-600 CTO Hard drive Replacement: 步骤 2 中的图像 2,2
    • Place your index finger on the ridged tab.
  3. HP G60T-600 CTO Hard drive Replacement: 步骤 3 中的图像 1,1
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. HP G60T-600 CTO Hard drive Replacement, Hard drive: 步骤 4 中的图像 1,2 HP G60T-600 CTO Hard drive Replacement, Hard drive: 步骤 4 中的图像 2,2
    • Remove the 5cm screws with a #00 Phillips screwdriver.
    • Take the cover off.
  5. HP G60T-600 CTO Hard drive Replacement: 步骤 5 中的图像 1,3 HP G60T-600 CTO Hard drive Replacement: 步骤 5 中的图像 2,3 HP G60T-600 CTO Hard drive Replacement: 步骤 5 中的图像 3,3
    • Remove the following .5cm screws with a #0 Phillips screwdriver.
    • Slide the hard drive cover to the right with light-medium force.
  6. HP G60T-600 CTO Hard drive Replacement: 步骤 6 中的图像 1,1
    • Pull up on the little black tab on the hard drive case to remove it.
    • From here you will be able to carefully slide your hard drive out.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 4-5, Catania Fall 2016 UMass Dartmouth, Team 4-5, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 188
