跳转到主内容
HP G60T-600 CTO CD Player Replacement
你所需要的
  1. HP G60T-600 CTO CD Player Replacement, Battery: 步骤 1 中的图像 1,1
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. HP G60T-600 CTO CD Player Replacement: 步骤 2 中的图像 1,2 HP G60T-600 CTO CD Player Replacement: 步骤 2 中的图像 2,2
    • Place your index finger on the ridged tab.
  3. HP G60T-600 CTO CD Player Replacement: 步骤 3 中的图像 1,1
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. HP G60T-600 CTO CD Player Replacement, Keyboard: 步骤 4 中的图像 1,2 HP G60T-600 CTO CD Player Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Unscrew the following 5mm screws with a #0 Phillips screwdriver.
  5. HP G60T-600 CTO CD Player Replacement: 步骤 5 中的图像 1,1
    • Turn your laptop over and open it up.
    • Grip your laptop firmly from both sides and use your thumbs to slide the keyboard towards the screen.
  6. HP G60T-600 CTO CD Player Replacement: 步骤 6 中的图像 1,1
    • Pull up on the top of your keyboard with medium force. It should start to pop out.
    • A plastic opening tool may facilitate this task.
    • Run your hands underneath the edges of the keyboard until it is free from the device.
    • Do not pull hard to take the keyboard out. There is a small connection that needs to be undone.
  7. HP G60T-600 CTO CD Player Replacement: 步骤 7 中的图像 1,2 HP G60T-600 CTO CD Player Replacement: 步骤 7 中的图像 2,2
    • Place your thumbs on the two small, white tabs.
    • Push these tabs forward to release the connection and free the keyboard from the device.
  8. HP G60T-600 CTO CD Player Replacement, Power Button Frame: 步骤 8 中的图像 1,1
    • Similarly to how you remove the keyboard, gently pry a small section of the power button frame up.
  9. HP G60T-600 CTO CD Player Replacement: 步骤 9 中的图像 1,2 HP G60T-600 CTO CD Player Replacement: 步骤 9 中的图像 2,2
    • Gently pull the white tab upwards.
    • With similar force, pull the connection out.
    • You are now free to pull the power button frame off of your device.
  10. HP G60T-600 CTO CD Player Replacement: 步骤 10 中的图像 1,1
    • Unscrew the 5mm screw holding the CD player in place.
  11. HP G60T-600 CTO CD Player Replacement, CD Player: 步骤 11 中的图像 1,3 HP G60T-600 CTO CD Player Replacement, CD Player: 步骤 11 中的图像 2,3 HP G60T-600 CTO CD Player Replacement, CD Player: 步骤 11 中的图像 3,3
    • Slide the CD player case away from the device with medium-hard force, it should come right out.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 4-5, Catania Fall 2016 UMass Dartmouth, Team 4-5, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 106
