跳转到主内容
HP G60-443CL Battery Replacement
你所需要的
  1. HP G60-443CL Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the laptop upside down where the headphone and auxiliary jack are facing you.
  2. HP G60-443CL Battery Replacement: 步骤 2 中的图像 1,1
    • In the top left corner, there is a lever that has a small picture of a battery on it. Slide the lever to the left.
  3. HP G60-443CL Battery Replacement: 步骤 3 中的图像 1,1
    • Once you have slid the lever to the left, the front part of the battery will be released and you should be able to grab the released part of the battery with your thumb.
  4. HP G60-443CL Battery Replacement: 步骤 4 中的图像 1,1
    • The battery can then be pulled out of its compartment by hand.
结论
Alora Allen
于11/06/17注册
101 声望
撰写一个指南
团队
Baylor, Team S8-G7, Johnson Fall 2017 Baylor, Team S8-G7, Johnson Fall 2017 的会员
BU-JOHNSON-F17S8G7
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 343
