跳转到主内容
HP G60 RAM Replacement
你所需要的
  1. HP G60 RAM Replacement, Battery: 步骤 1 中的图像 1,3 HP G60 RAM Replacement, Battery: 步骤 1 中的图像 2,3 HP G60 RAM Replacement, Battery: 步骤 1 中的图像 3,3
    • First, you should to remove the battery to avoid electric shocks
    • Slide and unlock the battery, then, lift it
  2. HP G60 RAM Replacement, RAM cover: 步骤 2 中的图像 1,3 HP G60 RAM Replacement, RAM cover: 步骤 2 中的图像 2,3 HP G60 RAM Replacement, RAM cover: 步骤 2 中的图像 3,3
    • Remove the two screws with a not too large screwdriver
    • Now lift the cover, the screws are part of the cover
  3. HP G60 RAM Replacement, Eject RAM: 步骤 3 中的图像 1,3 HP G60 RAM Replacement, Eject RAM: 步骤 3 中的图像 2,3 HP G60 RAM Replacement, Eject RAM: 步骤 3 中的图像 3,3
    • Push the little aluminum locks at the top and the bottom of the ram
    • The memory will lift, then pull it
    • Make this with the another RAM slot
  4. HP G60 RAM Replacement, New RAM: 步骤 4 中的图像 1,3 HP G60 RAM Replacement, New RAM: 步骤 4 中的图像 2,3 HP G60 RAM Replacement, New RAM: 步骤 4 中的图像 3,3
    • The new RAM memory should to be insert in a 45 degrees angle
    • Then, push it and the memory will lock by itself
    • Make this with the second memory
  5. HP G60 RAM Replacement, RAM cover (Again): 步骤 5 中的图像 1,3 HP G60 RAM Replacement, RAM cover (Again): 步骤 5 中的图像 2,3 HP G60 RAM Replacement, RAM cover (Again): 步骤 5 中的图像 3,3
    • Insert the cover from right to left, then, screw it
    • If cover is lifted, press it softly and secure it
终点
5等其他人完成本指南。
jimenezser
于08/29/12注册
3,848 声望
创作了4篇指南
一条评论
Thanks for verifying the RAM replacement and that it was as easy as I thought it was, but that made me a bit nervous, being much more comfortable building desktops as large as my or my customer's budget would allow!
Take 'em out, put new ones back in. As a technical writer, I also appreciate that you kept it to the point without creating further questions to complicate that which is not complicated. Thanks again. Will check out some out your other work.
J Brent Masters - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 6,040
