跳转到主内容
HP Folio 13t-1000 Battery Replacement
你所需要的
  1. HP Folio 13t-1000 Battery Replacement, Keyboard: 步骤 1 中的图像 1,2 HP Folio 13t-1000 Battery Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Use an antistatic wrist wrap, or periodically touch unpainted metal to minimize the risk of damaging the laptop by electrostatic shock.
    • Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
  2. HP Folio 13t-1000 Battery Replacement: 步骤 2 中的图像 1,3 HP Folio 13t-1000 Battery Replacement: 步骤 2 中的图像 2,3 HP Folio 13t-1000 Battery Replacement: 步骤 2 中的图像 3,3
    • This step requires unlocking the very fragile plastic clips along the frame; take care not to damage them.
    • Slide the spudger with a twisting motion along the entire perimeter of the laptop until the top cover is separated from the frame of the device.
  3. HP Folio 13t-1000 Battery Replacement: 步骤 3 中的图像 1,1
    • Using the flat portion of the plastic spudger, push the corner of the black surface until the first clip unlocks.
    • The top right corner of the keyboard should now be sticking out slightly.
    • Repeat the same process for the top left corner.
  4. HP Folio 13t-1000 Battery Replacement: 步骤 4 中的图像 1,2 HP Folio 13t-1000 Battery Replacement: 步骤 4 中的图像 2,2
    • Slide the keyboard up and towards the screen just enough to separate the keyboard from the top cover.
  5. HP Folio 13t-1000 Battery Replacement: 步骤 5 中的图像 1,3 HP Folio 13t-1000 Battery Replacement: 步骤 5 中的图像 2,3 HP Folio 13t-1000 Battery Replacement: 步骤 5 中的图像 3,3
    • To unlock the clamps connected to the motherboard, use your fingers or insert the pointed edge of the spudger between the first clamp and the cable.
    • Repeat the same process for the second clamp.
  6. HP Folio 13t-1000 Battery Replacement: 步骤 6 中的图像 1,3 HP Folio 13t-1000 Battery Replacement: 步骤 6 中的图像 2,3 HP Folio 13t-1000 Battery Replacement: 步骤 6 中的图像 3,3
    • Remove the keyboard from the laptop.
  7. HP Folio 13t-1000 Battery Replacement, Top Hardware Cover: 步骤 7 中的图像 1,3 HP Folio 13t-1000 Battery Replacement, Top Hardware Cover: 步骤 7 中的图像 2,3 HP Folio 13t-1000 Battery Replacement, Top Hardware Cover: 步骤 7 中的图像 3,3
    • Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
    • Do the same for the second connection.
  8. HP Folio 13t-1000 Battery Replacement: 步骤 8 中的图像 1,2 HP Folio 13t-1000 Battery Replacement: 步骤 8 中的图像 2,2
    • Remove the top hardware cover.
  9. HP Folio 13t-1000 Battery Replacement, Battery: 步骤 9 中的图像 1,2 HP Folio 13t-1000 Battery Replacement, Battery: 步骤 9 中的图像 2,2
    • Use a PH1 screw head to remove the two, 3mm screws.
  10. HP Folio 13t-1000 Battery Replacement: 步骤 10 中的图像 1,1
    • Remove the motherboard connection using the nylon spudger or your fingers.
  11. HP Folio 13t-1000 Battery Replacement: 步骤 11 中的图像 1,1
    • Separate the ribbon from the battery by wedging the flat metal spudger between the two.
  12. HP Folio 13t-1000 Battery Replacement: 步骤 12 中的图像 1,2 HP Folio 13t-1000 Battery Replacement: 步骤 12 中的图像 2,2
    • Remove old battery and replace with a new one.
结论
Cody Badchkam
于09/28/16注册
64 声望
创作了4篇指南
团队
USF Tampa, Team 1-2, Cagle Fall 2016 USF Tampa, Team 1-2, Cagle Fall 2016 的会员
USFT-CAGLE-F16S1G2
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 12
总计 609
