跳转到主内容
加入维修社区 - 创建账户
HP Flyer Red Keyboard Replacement
你所需要的
    1. HP Flyer Red Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 HP Flyer Red Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
      • Make sure your laptop is powered off.
      • With laptop closed flip to look at the underside of the laptop.
      询问修复机器人
      添加评论
    2. HP Flyer Red Keyboard Replacement: 步骤 2 中的图像 1,1
      • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
      询问修复机器人
      添加评论
    3. HP Flyer Red Keyboard Replacement: 步骤 3 中的图像 1,2 HP Flyer Red Keyboard Replacement: 步骤 3 中的图像 2,2
      • The left switch is the battery unlock switch.
      • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
      询问修复机器人
      添加评论
    4. HP Flyer Red Keyboard Replacement: 步骤 4 中的图像 1,1
      • Then take and slide the other switch to the other end of its track which will pop out the battery.
      • Grab the battery and pull it out of the slot.
      询问修复机器人
      添加评论
    1. HP Flyer Red Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,2 HP Flyer Red Keyboard Replacement, Keyboard: 步骤 5 中的图像 2,2
      • Next locate and unscrew the two 4mm Phllips #1 screws with the keyboard symbol located towards the middle and top of the bottom of the laptop.
      询问修复机器人
      添加评论
    2. HP Flyer Red Keyboard Replacement: 步骤 6 中的图像 1,3 HP Flyer Red Keyboard Replacement: 步骤 6 中的图像 2,3 HP Flyer Red Keyboard Replacement: 步骤 6 中的图像 3,3
      • Next turn the laptop over and flip open the screen.
      • Use the plastic opening tool to pry the keyboard upwards from the bottom right hand corner of the keyboard.
      • Use another plastic opening tool with the first plastic opening tool you placed to undo every plastic clasp surrounding the keyboard.
      询问修复机器人
      添加评论
    3. HP Flyer Red Keyboard Replacement: 步骤 7 中的图像 1,3 HP Flyer Red Keyboard Replacement: 步骤 7 中的图像 2,3 HP Flyer Red Keyboard Replacement: 步骤 7 中的图像 3,3
      • Next lift up the keyboard gently and use the plastic opening tool to undo the ribbon wire by unclasping the ZIF (zero insertion force) connector to the laptop.
      • Gently slide the ribbon wire out of its slot.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 25
总计 2,619
