跳转到主内容
HP Flyer Red Battery Replacement
Anthony Ciotti
Anthony Ciotti3 其他贡献者
最后更新于 May 20, 2016
2分钟
非常容易
We will show step by step progression of how to unlock the battery and remove it. This guide will help you understand the fundamentals of a battery replacement with this HP laptop. This guide is useful if you have a new battery and are looking to swap it out with the old one.
  1. HP Flyer Red Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP Flyer Red Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
  2. HP Flyer Red Battery Replacement: 步骤 2 中的图像 1,1
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
  3. HP Flyer Red Battery Replacement: 步骤 3 中的图像 1,2 HP Flyer Red Battery Replacement: 步骤 3 中的图像 2,2
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
  4. HP Flyer Red Battery Replacement: 步骤 4 中的图像 1,1
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
结论
6等其他人完成本指南。
Anthony Ciotti
于04/07/16注册
762 声望
创作了5篇指南
团队
UMass Dartmouth, Team 4-5, Catania Spring 2016 UMass Dartmouth, Team 4-5, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S4G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 10
总计 2,384
