跳转到主内容
HP FHA-3510 Wireless Mouse Button Replacement
你所需要的
  1. HP FHA-3510 Wireless Mouse Button Replacement, Button: 步骤 1 中的图像 1,2 HP FHA-3510 Wireless Mouse Button Replacement, Button: 步骤 1 中的图像 2,2
    • Turn off the mouse and remove the silver (or other colored) top cover.
  2. HP FHA-3510 Wireless Mouse Button Replacement: 步骤 2 中的图像 1,1
    • Remove the screws and keep them safe. One screw is under where the battery was located.
    • Gently lift the cover from the mouse to reveal the Printed Circuit Board.
  3. HP FHA-3510 Wireless Mouse Button Replacement: 步骤 3 中的图像 1,1
    • Study how the antenna wire in front of the mouse wheel and the mouse wheel assembly are located into the PCB. You'll need to know this when you perform the re-assembly. Also note which side the power switch is set to.
    • Remove the mouse wheel from the assembly, then remove the PCB.
    • The tactile switches for the left, right or page down buttons are tall black and square devices. One can be seen next to the wire in the picture.
  4. HP FHA-3510 Wireless Mouse Button Replacement: 步骤 4 中的图像 1,2 HP FHA-3510 Wireless Mouse Button Replacement: 步骤 4 中的图像 2,2
    • The new EVQ P0E07K can be seen in the image.
    • Using your soldering Iron, de-solder the old switch by placing tweezers under the switch for leverage whilst heating the pins.
    • You may find it easier to wriggle the switch out one pin at a time, rather than heating both pins at once.
    • De-solder the holes with the solder pump or wick.
    • Insert the new buttons and solder, ensuring they are flush with the PCB.
    • Re-assemble the mouse carefully ensuring the power switch, lens, antenna and mouse wheel are in the correct locations.
    • Test the switch works acceptably before screwing the unit back together.
结论
2等其他人完成本指南。
Michael Walsh
于05/14/12注册
171 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 56
总计 8,509
