跳转到主内容
HP Envy x360 m6-w105dx Battery Replacement
你所需要的
  1. HP Envy x360 m6-w105dx Battery Replacement, Keyboard: 步骤 1 中的图像 1,3 HP Envy x360 m6-w105dx Battery Replacement, Keyboard: 步骤 1 中的图像 2,3 HP Envy x360 m6-w105dx Battery Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Make sure the laptop is powered off and disconnected from any outlets.
    • Use the opening pick to lift up the eight rubber grips on the underside of the device.
    • With the #1 Phillips screwdriver, remove the twelve 6mm screws from the back case.
  2. HP Envy x360 m6-w105dx Battery Replacement: 步骤 2 中的图像 1,2 HP Envy x360 m6-w105dx Battery Replacement: 步骤 2 中的图像 2,2
    • Open the laptop and turn to the keyboard.
    • Gently insert an opening pick into the edge of the keyboard panel, and slide around the keyboard lining until the clips have all been disengaged.
    • Lift the keyboard panel from the bottom and carefully start to lift up.
    • There are ribbon cables still connected on the under side of the the keyboard. Do not pull the keyboard away from the device.
  3. HP Envy x360 m6-w105dx Battery Replacement: 步骤 3 中的图像 1,2 HP Envy x360 m6-w105dx Battery Replacement: 步骤 3 中的图像 2,2
    • Gently lift the keyboard up from the bottom.
    • Carefully open the locking flap of the three ZIF connectors and detach the three ribbon cables from the motherboard using your fingers.
    • Do not remove the ZIF connectors by pulling on the wires, instead detach them by gently flipping up the plastic tabs located at the ends of the wiring.
    • Fully remove the keyboard from the laptop and install your new keyboard.
  4. HP Envy x360 m6-w105dx Battery Replacement, Battery: 步骤 4 中的图像 1,2 HP Envy x360 m6-w105dx Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Carefully flip up the locking tabs on the ZIF connectors and remove the ribbon cables from the connectors.
    • Disconnect the battery cable by sliding it downward from the connector with an iFixit opening tool.
    • Using this tool reduces the chance of any sparking or electronic charge.
  5. HP Envy x360 m6-w105dx Battery Replacement: 步骤 5 中的图像 1,2 HP Envy x360 m6-w105dx Battery Replacement: 步骤 5 中的图像 2,2
    • Using the Phillips #1 screwdriver, unscrew the four 6 mm screws.
  6. HP Envy x360 m6-w105dx Battery Replacement: 步骤 6 中的图像 1,2 HP Envy x360 m6-w105dx Battery Replacement: 步骤 6 中的图像 2,2
    • Gently lift the battery up from the case and replace it.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 26
总计 1,803
