跳转到主内容
HP Envy x360 m6-aq105dx Battery Replacement
你所需要的
  1. HP Envy x360 m6-aq105dx Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Battery Replacement: 步骤 2 中的图像 1,1
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Attach the grounding bracelet's clip to the frame of the laptop, then put on the grounding bracelet.
    • Remove the six 4.6mm screws securing the battery using the Phillips #0 screwdriver.
  4. HP Envy x360 m6-aq105dx Battery Replacement: 步骤 4 中的图像 1,1
    • Disconnect the power supply cable connected to the motherboard.
  5. HP Envy x360 m6-aq105dx Battery Replacement: 步骤 5 中的图像 1,2 HP Envy x360 m6-aq105dx Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the battery from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 17
总计 1,144
