跳转到主内容
HP Envy x360 m6-aq105dx Back Cover Replacement
你所需要的
  1. HP Envy x360 m6-aq105dx Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Back Cover Replacement: 步骤 2 中的图像 1,1
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 546
