跳转到主内容
HP Envy x360 m6-aq103dx Hard drive Replacement
你所需要的
  1. HP Envy x360 m6-aq103dx Hard drive Replacement, Bottom Cover: 步骤 1 中的图像 1,3 HP Envy x360 m6-aq103dx Hard drive Replacement, Bottom Cover: 步骤 1 中的图像 2,3 HP Envy x360 m6-aq103dx Hard drive Replacement, Bottom Cover: 步骤 1 中的图像 3,3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Hard drive Replacement: 步骤 2 中的图像 1,1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Hard drive Replacement: 步骤 3 中的图像 1,1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Hard drive Replacement: 步骤 4 中的图像 1,3 HP Envy x360 m6-aq103dx Hard drive Replacement: 步骤 4 中的图像 2,3 HP Envy x360 m6-aq103dx Hard drive Replacement: 步骤 4 中的图像 3,3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Hard drive Replacement, Hard Drive: 步骤 5 中的图像 1,3 HP Envy x360 m6-aq103dx Hard drive Replacement, Hard Drive: 步骤 5 中的图像 2,3 HP Envy x360 m6-aq103dx Hard drive Replacement, Hard Drive: 步骤 5 中的图像 3,3
    • Disconnect the ribbon cable with the purple tag by flipping the black tab with the plastic opening tool.
    • Disconnect the ribbon cable by gently pulling it away from the connector with your fingers.
  6. HP Envy x360 m6-aq103dx Hard drive Replacement: 步骤 6 中的图像 1,3 HP Envy x360 m6-aq103dx Hard drive Replacement: 步骤 6 中的图像 2,3 HP Envy x360 m6-aq103dx Hard drive Replacement: 步骤 6 中的图像 3,3
    • Remove the two Phillips head screws (5 mm) using the Phillip's head #1 screwdriver.
    • Use your hands to lift the hard drive up and remove it.
结论
5等其他人完成本指南。
Jordan Eremeyeff
于10/01/17注册
597 声望
创作了3篇指南
团队
Cal Poly, Team S4-G3, Livingston Fall 2017 Cal Poly, Team S4-G3, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S4G3
4 名成员
创作了9篇指南
一条评论
Great guide. Only thing i did different was not removing the ribbon cable. It’s not necessary. Just unscrew the hard drive enclosure and you’ll have plenty of room to disconnect the sata connector plugged in to the drive.
Ron H - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 26
总计 7,110
