跳转到主内容
HP Envy x360 m6-aq103dx Bottom Cover Replacement
你所需要的
  1. HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 1,3 HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 2,3 HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 3,3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Bottom Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Bottom Cover Replacement: 步骤 3 中的图像 1,1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Bottom Cover Replacement: 步骤 4 中的图像 1,3 HP Envy x360 m6-aq103dx Bottom Cover Replacement: 步骤 4 中的图像 2,3 HP Envy x360 m6-aq103dx Bottom Cover Replacement: 步骤 4 中的图像 3,3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
结论
8等其他人完成本指南。
Sarah Samora
于10/02/17注册
777 声望
创作了3篇指南
团队
Cal Poly, Team S4-G3, Livingston Fall 2017 Cal Poly, Team S4-G3, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S4G3
4 名成员
创作了9篇指南
4条评论
what should I do if I don’t have a nylon spudger? Is it safe to use my fingers to pry it open? I know I need to be careful about static or else it could fry the comp.
Joshua Bowman - 回复
It was really easy to open.
[deleted] - 回复
Glad I read this…didn't know about the 2 screws under the grip pads. Once again the internet comes through.
MrHarris73 - 回复
But where can i purchase the bottom cover
imran abdulhameed - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 57
总计 8,639
