跳转到主内容
HP Envy x360 m6-aq103dx Battery Replacement
你所需要的
  1. HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: 步骤 1 中的图像 1,3 HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: 步骤 1 中的图像 2,3 HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: 步骤 1 中的图像 3,3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Battery Replacement: 步骤 4 中的图像 1,3 HP Envy x360 m6-aq103dx Battery Replacement: 步骤 4 中的图像 2,3 HP Envy x360 m6-aq103dx Battery Replacement: 步骤 4 中的图像 3,3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Battery Replacement, Battery: 步骤 5 中的图像 1,2 HP Envy x360 m6-aq103dx Battery Replacement, Battery: 步骤 5 中的图像 2,2
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx Battery Replacement: 步骤 6 中的图像 1,3 HP Envy x360 m6-aq103dx Battery Replacement: 步骤 6 中的图像 2,3 HP Envy x360 m6-aq103dx Battery Replacement: 步骤 6 中的图像 3,3
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx Battery Replacement: 步骤 7 中的图像 1,3 HP Envy x360 m6-aq103dx Battery Replacement: 步骤 7 中的图像 2,3 HP Envy x360 m6-aq103dx Battery Replacement: 步骤 7 中的图像 3,3
    • Lift the battery out of the laptop with your hands.
结论
5等其他人完成本指南。
Sarah Samora
于10/02/17注册
777 声望
创作了3篇指南
团队
Cal Poly, Team S4-G3, Livingston Fall 2017 Cal Poly, Team S4-G3, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S4G3
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 28
总计 7,459
