跳转到主内容
HP Envy x360 m6-aq005dx Keyboard Replacement
你所需要的
  1. HP Envy x360 m6-aq005dx Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 HP Envy x360 m6-aq005dx Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 HP Envy x360 m6-aq005dx Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Use the Phillips #0 screw driver head to remove the two 7.8mm screws that secure the bottom cover to the computer.
    • Use the Phillips #00 screw driver head to remove the six 5.2mm screws that secure the bottom cover to the computer.
    • Insert the iFixit plastic prying tool between the bottom cover and bottom chassis.
    • Lift the cover carefully off the machine.
  2. HP Envy x360 m6-aq005dx Keyboard Replacement: 步骤 2 中的图像 1,3 HP Envy x360 m6-aq005dx Keyboard Replacement: 步骤 2 中的图像 2,3 HP Envy x360 m6-aq005dx Keyboard Replacement: 步骤 2 中的图像 3,3
    • Use the Phillips #00 screw driver head to remove the six 4.6mm screws that secure the battery to the top cover.
    • Disconnect the battery cable from the motherboard.
    • Lift to remove the battery and set it to the side.
  3. HP Envy x360 m6-aq005dx Keyboard Replacement: 步骤 3 中的图像 1,3 HP Envy x360 m6-aq005dx Keyboard Replacement: 步骤 3 中的图像 2,3 HP Envy x360 m6-aq005dx Keyboard Replacement: 步骤 3 中的图像 3,3
    • Use the Phillips #00 screw driver head to remove the three 4.6mm screws that secure the fan to the top cover.
    • Release the display panel cable from the retention clips and channel built into the fan.
    • Use the Phillips #0 screw driver head to remove the four 6.2mm captive screws that secure the fan/ heat sink assembly to the motherboard.
    • Remove the fan/heat sink assembly.
  4. HP Envy x360 m6-aq005dx Keyboard Replacement: 步骤 4 中的图像 1,3 HP Envy x360 m6-aq005dx Keyboard Replacement: 步骤 4 中的图像 2,3 HP Envy x360 m6-aq005dx Keyboard Replacement: 步骤 4 中的图像 3,3
    • Use the Phillips #00 screw driver head to remove the following screws that secure the motherboard to the top cover:
    • Four 4.6mm screws;
    • Two 3.3 mm screws.
    • Use the Phillips #0 screw driver head to remove the one 4.5mm screw that secure the system board to the top cover.
    • Use the iFixit plastic prying tool to disconnect the seven marked data cables linked to the system board.
    • Lift the motherboard to remove it from the top cover.
  5. HP Envy x360 m6-aq005dx Keyboard Replacement: 步骤 5 中的图像 1,2 HP Envy x360 m6-aq005dx Keyboard Replacement: 步骤 5 中的图像 2,2
    • Use the Phillips #00 screw driver head to remove the three 4.6mm screws that secure the hard drive to the top cover.
    • Remove the hard drive.
  6. HP Envy x360 m6-aq005dx Keyboard Replacement: 步骤 6 中的图像 1,3 HP Envy x360 m6-aq005dx Keyboard Replacement: 步骤 6 中的图像 2,3 HP Envy x360 m6-aq005dx Keyboard Replacement: 步骤 6 中的图像 3,3
    • Use the Phillips #0 screw driver head to remove the six 4.5mm screws that secure the display assembly to the keyboard/ top cover.
    • Use the Phillips #00 screw driver head to remove the three 3.3mm screw that secure the connector board to the keyboard/top cover then remove the connector board.
    • Replace the keyboard.
结论
2等其他人完成本指南。
Bo Sun
于10/08/16注册
183 声望
撰写一个指南
团队
IUPUI, Team S4-G4, Wilson Fall 2019 IUPUI, Team S4-G4, Wilson Fall 2019 的会员
IUPUI-WILSON-F19S4G4
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 1,179
