跳转到主内容
HP Envy x360 m6-aq005dx Battery Replacement
你所需要的
  1. HP Envy x360 m6-aq005dx Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 HP Envy x360 m6-aq005dx Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. HP Envy x360 m6-aq005dx Battery Replacement: 步骤 2 中的图像 1,3 HP Envy x360 m6-aq005dx Battery Replacement: 步骤 2 中的图像 2,3 HP Envy x360 m6-aq005dx Battery Replacement: 步骤 2 中的图像 3,3
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. HP Envy x360 m6-aq005dx Battery Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  4. HP Envy x360 m6-aq005dx Battery Replacement, Battery: 步骤 4 中的图像 1,2 HP Envy x360 m6-aq005dx Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Use a JIS #1 screwdriver to remove the six 4.7 mm screws.
  5. HP Envy x360 m6-aq005dx Battery Replacement: 步骤 5 中的图像 1,1
    • Battery might cause a small electric shock.
    • Use tweezers to disconnect the battery from the motherboard.
结论
7等其他人完成本指南。
Matthew Martin
于10/10/17注册
711 声望
创作了5篇指南
团队
USF Tampa, Team S13-G17, Cagle Fall 2017 USF Tampa, Team S13-G17, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G17
4 名成员
创作了7篇指南
3条评论
Step 3 was the toughest!!! Case was difficult to separate.
Bo Hagen - 回复
Thank you!!!! This made it sooooo easy to replace my battery!
Michelle Kuhlmann - 回复
Excellent guide, many thanks for posting it.
stephenm.race - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 26
总计 15,570
