跳转到主内容
HP Envy x360 m6-aq003dx CPU Fan Replacement
你所需要的
  1. HP Envy x360 m6-aq003dx CPU Fan Replacement, Back Panel: 步骤 1 中的图像 1,3 HP Envy x360 m6-aq003dx CPU Fan Replacement, Back Panel: 步骤 1 中的图像 2,3 HP Envy x360 m6-aq003dx CPU Fan Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Turn the laptop over and use the plastic opening tool to take off the rubber pads. You only need to take off the two pads at the top for this device.
  2. HP Envy x360 m6-aq003dx CPU Fan Replacement: 步骤 2 中的图像 1,3 HP Envy x360 m6-aq003dx CPU Fan Replacement: 步骤 2 中的图像 2,3 HP Envy x360 m6-aq003dx CPU Fan Replacement: 步骤 2 中的图像 3,3
    • Use the Torx T5 screwdriver to remove the six small screws.
    • Use the Phillips #0 screwdriver to remove the screws under the rubber pads in step 1.
  3. HP Envy x360 m6-aq003dx CPU Fan Replacement: 步骤 3 中的图像 1,1
    • Go slowly around the edge with the opening tool. The noises you will hear are due to the small joints popping open. Continue this until you have made your way around the entire laptop.
  4. HP Envy x360 m6-aq003dx CPU Fan Replacement, CPU Fan: 步骤 4 中的图像 1,3 HP Envy x360 m6-aq003dx CPU Fan Replacement, CPU Fan: 步骤 4 中的图像 2,3 HP Envy x360 m6-aq003dx CPU Fan Replacement, CPU Fan: 步骤 4 中的图像 3,3
    • Disconnect the port of the fan by flipping the black tab with the small blue plastic opening tool.
    • Remove the cable from the connector.
  5. HP Envy x360 m6-aq003dx CPU Fan Replacement: 步骤 5 中的图像 1,2 HP Envy x360 m6-aq003dx CPU Fan Replacement: 步骤 5 中的图像 2,2
    • Remove the black cable from the fan by unclicking it from the plastic body of the fan with your fingers.
    • You will hear clicking sounds when the black cable is removed.
  6. HP Envy x360 m6-aq003dx CPU Fan Replacement: 步骤 6 中的图像 1,2 HP Envy x360 m6-aq003dx CPU Fan Replacement: 步骤 6 中的图像 2,2
    • Disconnect the port with the red, yellow, and black wires by removing the wires with your fingers.
  7. HP Envy x360 m6-aq003dx CPU Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the two 4.5mm Phillips #1 screws.
  8. HP Envy x360 m6-aq003dx CPU Fan Replacement: 步骤 8 中的图像 1,2 HP Envy x360 m6-aq003dx CPU Fan Replacement: 步骤 8 中的图像 2,2
    • Loosen the four black screws on the tail end of the fan with a Phillips head 1 screwdriver.
    • These screws do not come off.
  9. HP Envy x360 m6-aq003dx CPU Fan Replacement: 步骤 9 中的图像 1,3 HP Envy x360 m6-aq003dx CPU Fan Replacement: 步骤 9 中的图像 2,3 HP Envy x360 m6-aq003dx CPU Fan Replacement: 步骤 9 中的图像 3,3
    • Lift the CPU fan out with your hand.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 405
