跳转到主内容
HP Envy x360 m6-aq003dx Battery Replacement
你所需要的
  1. HP Envy x360 m6-aq003dx Battery Replacement, Back Panel: 步骤 1 中的图像 1,3 HP Envy x360 m6-aq003dx Battery Replacement, Back Panel: 步骤 1 中的图像 2,3 HP Envy x360 m6-aq003dx Battery Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Turn the laptop over and use the plastic opening tool to take off the rubber pads. You only need to take off the two pads at the top for this device.
  2. HP Envy x360 m6-aq003dx Battery Replacement: 步骤 2 中的图像 1,3 HP Envy x360 m6-aq003dx Battery Replacement: 步骤 2 中的图像 2,3 HP Envy x360 m6-aq003dx Battery Replacement: 步骤 2 中的图像 3,3
    • Use the Torx T5 screwdriver to remove the six small screws.
    • Use the Phillips #0 screwdriver to remove the screws under the rubber pads in step 1.
  3. HP Envy x360 m6-aq003dx Battery Replacement: 步骤 3 中的图像 1,1
    • Go slowly around the edge with the opening tool. The noises you will hear are due to the small joints popping open. Continue this until you have made your way around the entire laptop.
  4. HP Envy x360 m6-aq003dx Battery Replacement, Battery: 步骤 4 中的图像 1,2 HP Envy x360 m6-aq003dx Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the six 4mm screws around the battery using a Phillips #0 screwdriver.
  5. HP Envy x360 m6-aq003dx Battery Replacement: 步骤 5 中的图像 1,1
    • Disconnect the white connector from the battery to the board. (It is recommended to use pliers to remove the cord to avoid touching the board).
    • Once the connector and screws are both removed, lift the battery up and remove it from the laptop.
    • The removal of the connector and the screws can be done in either order.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 967
